New antenna from Sirio Gain-Master
im not sure if im comparing apples and oranges here, but doesnt an extended double zepp antenna use .64 wavelength for each leg?
Yes, actually, it often is .64, however some simply use .625 or call .64 a "5/8" for simplicity.
By posting:
The double extended Zep uses two 5/8 wave radiators. The .64 wave only seems to have a home on CB.
Shockwave is attempting to mislead you into believing there is never a .64 antenna length used by Amateurs, only by deceived CBers.
Here are just a few links to some of the many available websites showing examples of Amateurs using .64 for their extended double zepp antenna calculations.
Double-extended Zepp
Now who is the deceived,
...or the deceiver?
i'm not sure .64 is even relevant, even to the hy gain penetrator 500. in 3 manuals and vintage advertising on cb tricks, nowhere does hy gain claim the penetrator is .64 wave, infact on all 4 pieces of documentation from hy gain they claim its a full size 5/8 wave. don't take my word for it, check it out on cb tricks.
i've never heard .64 mentioned in any other radio/tv publication except for cb, which suggests to me its just another piece of bullshit hype marketing, most likely from dealers as from what i can see it definately isn't being claimed by hy gain.
as for radials cancelling out the bottom 1/8 wave radiation, surely the radials would have to be more than 4 feet above the feedpoint, not 12-14 inches for that to even be contemplated, as it has 4 equal sized radials at right angles then cancellation from radials opposite each other would prevent radiation from the radials which if i'm not mistaken radiation would be required to cancel out radiation from the radiator bottom 1/8 wave which is out of phase.
another thing that strikes me is nearly every antenna be it 1/2 wave vertical (silver rod) or 5/8 wave vertical uses the exact same radial/bracket arrangement,including many ham and commercial antennas, yet i've never seen one manufacturer claim it made the slightest bit of difference in over 30 years of radio, i find that staggering seeing as nearly every other aspect of antennas has at one time or another been claimed by the deluded to improve things over their competition.
i'm also certain if it did provide any gain it would have been the bracket style used on the A99 so that radials could be added easily to improve the 9.9dbi gain claimed by solarconmen.
i'm sensing a lot of snake oil on this penetrator 500 (probably more out of sentiment than reality), i doubt very much its any different to any other 5/8 wave apart from maybe tiny gain from having a better quality/less lossy coil than other antennas, but i doubt very much even if that was the case that it would be measureable without some very sophisticated test gear and an anechoic chamber.
this is just my own personal opinion.
By posting:
...or the deceiver?
from your first link Scott, i'd seriously check out all the info on that site, as i've noticed a couple of innacuracies previously, before you take it as gospel, the third link looks like its either been copied from the first or vice versa, the schematic of the double zepp is exactly the same in both,bit of plagerism going on there methinks.
the other two links i don't even see .64 mentioned except from the lengths being the same as the other two sites, again makes me wonder which one is the true source.
A key thing about the word Amateur is its meaning ( very often overlooked), i think you'd find far more support for your claims if you were to quote professionals claiming the merit of .64 wave, that i think you will find very difficult to source, but i'm openminded enough to be proved wrong.
If you want to put this idea to the test, it couldn't be any simpler. Just use one of the models that contained the matching network in the base and not the hairpin because that will get in the way of the mod I propose. Then just cut the mounting bracket between the two U-bolt locations. Extend the radials higher on the radiator and connect the two halves of the mounting bracket back together with flat sheet metal. You could even use a mast with no paint on it to make the connection easily variable.
I can give you a whole list of sound technical reasons why this will degrade performance but lets just start with a couple. As you move the radials away from the grounded, unbalanced feed point, you create more inductance between the radials and the feed line they need to decouple. As you move the radials upwards on the vertical radiator, they must be insulated from the radiator and this forms a loading capacitor that is in parallel to all current feeding the main radiator.
Thanks. Finally, some sound theory injected into the discussion. I can see this . . . on my 5/8 I mounted it in a way that put the vertical radiator above the mast, but the GP remained at the very bottom of the vertical. I did it for both these very reasons. I notice the P500 utilizes a thin metal conductor running parallel to the main vertical to connect the braid of the feed line . . . Anything else?
By posting:
...or the deceiver?
First link: Clearly says the radiators are about 5/8 wave even though it contradicts itself in the copied diagram.
Second link: Clearly shows the radiators are exactly 5/8 wave to those who know how to do the calculations.
Third link: Gives three different measurements including .60 wave, 5/8 wave and .64 wave and copies the same picture. Clearly this person does not know what length is best.
Fourth link: Congratulations! You found one member of some ham club who agrees with your .64 calculations. I can point you to a thousand articles written by more knowledgeable people who disagree.
Jazz, you said exactly what I was going to say 1st and 3rd are knock off's of each other and if you read it they keep stating 5/8 wave in the text, the other 2 sites make no reference at all to .64, but i didnt do any calculations...
maybe its not important outside of coax , but ive noticed almost no antenna maker seems to take velocity factor into account . i dont recall who , but i recall someone saying aluminum has a %95 velocity in the air . maco might be since they recommend 248 inches for their 5/8 on 27MHz . %95 or 22.5 is a few hairs under 256 inches . im purely guessing that VF has anything to do with macos recommended length though .
to be honest mr suburban i didn't bother my ass doing calculations either,the first site i've read before and it has a few glaring mistakes liberally spattered over it, that was enough for me, the third one which was a copy of it or vice versa i clocked instantly,infact if you search .64 antennas on google its quite a common knock off, in much the same way as the i max 2000 being .64 is knocked off all over the web.
the other two didn't even mention .64 anywhere,but i'm sure if i did the calculations they'd all be 5/8 wave.
infact after i made the post my curiosity got the better of me, so i had a session with my best mate google to see if i could find any professional mention of .64 waves, surprise surprise not a one, all i could find was rehashed cb claims and rehashed double extended zepp claims, both of which i have doubts as to the credibility of the original sources let alone all the clones.
i did find one post on a cb forum where a guy claimed .64 was designated to differentiate between the less than 20 ft 5/8 waves that were only allowed prior to the 60 ft rule being introduced around 1970 and the longer 5/8 waves that appeared after that 20 ft rule was replaced, of all the things i've read about .64 that to me seems the most logical reason (albeit it might be wrong) and has nothing to do with claimed increased efficiency.
the internet is a fantastic tool for learning, but sadly its even better at propagating myths than facts, no doubt in part to the shortage of genuine knowledgeable people on radio tecnical aspects and the multitudes who delude themselves into believing they are knowledgeable.
i just wish my ssb signal propagated as efficiently as myths on the internet.
i would imagine the reason manufacturers give lengths without mentioning if they included vf is due to their contempt for the knowledge of most radio users.their bullshit claims tend to enforce that notion.
the medium surrounding the conductor is what decides the velocity factor, be it air,coax dielectric etc,unless you plan on using your antenna in a vacuum vf is something you have to consider, but its not the only thing that decides the length a twig needs to be, ground,surrounding objects etc all play a part.which is the reason most diy antenna builders give a start point usually slightly longer than required to allow for tuning in each specific situation.
another thing you have to be aware of is exactly where in the particular band you want your antenna centred on, not everyone uses the same bandwidth on any given band,for example on 11m i see anywhere between 26.000 and 28.000 as fair game, therefore centre all my antennas for 27.000, others prefer it centred on 27.555 or 27.185, others rarely stray away from a single channel and would centre it on their particular favourite channel or frequency. which is no doubt the reason you see so many slightly different lengths for the same antenna, not to mention the umpteen different formulas to be found for calculating antenna lengths,
the 102" steel whip is the classic example,no wonder people need to use springs on them because 102 inches is about 1.5 inches too short for centering on 27.185 if i recall,its more suited to the uk cb band which is higher in frequency/shorter in wavelength than the us cb band.despite this numerous people still go on about 102" being perfect.if i recall 102" originally came from the fibreglass encased whips which would have a slightly different velocity factor than a steel whip for the reason i mentioned earlier and would be shorter.
ie: 300/27.185 = 11.03m x 3.28 (to convert to feet) = 36.19 feet/4 (for 1/4 wave) = 9.04 feet x .95 (VF,more likely .97ish) = 8.59 feet x 12 (to convert to inches) = 103.15 inches.
assuming the VF is closer to .97 than .95 then you'd have:
300/27.185 = 11.03m x 3.28 = 36.19 feet/4 = 9.04 feet x .97 = 8.77 feet x 12 = 105.33 inches.
as you can see even with a VF in the range .95 - .97 102 inches is too short and the reason why you need to use a spring to get it to resonate.
if i recall here in the uk 1/4 whips were generally 108 inches which allowed plenty of room for manouverability right across 26-28 mhz.which would be a much better bet for the us market, ok it might involve a bit of whip trimming, but it won't be too short no matter where you tune it on 11m.
(i'm thinking they may be made deliberately too short to introduce capacitive reactance at centre frequency to give a lower swr reading than the 1.3:1 you would expect at resonance,i could be wrong as i can't be arsed doing anymore maths)
Guys,
The velocity factor for aluminium in air is around 1.
There is a slight difference depending on airpressure/humidity etc.
However, that is way to small to be of practical importancy. (like 0,995)
Another thing that lowers the resonant frequency is the increasement of diameter. The thicker material you use the shorter the total length will be. Pehaps that is often seen as "VF" ?
A velocity factor of 0,97 is typical for "random electrical wire" you know the one with a coating around them.
The velocity factor of coax can vary with what the manufacturer indicates.
For stacking yagi's i often use 75 ohm cable which suppose to have a VF of 0,85.
after doing measurements it 0,88 was found to be accurate.
Oke...back towards the radials.
I know that changing radials heigth has with about 6 inches on 3,5 Mhz will have a effect of only hundredths of a dB in difference (source w7xc).
And that effect was only cause it concernces "buried" radials. The "return" current had to travel though the soil.
If possible i would like to know what you guys mean with "decoupling" the coax cable.
Would that be the word for the work that a RF Choke does?
Kind regards,
Henry
11 meter Dx antenna systemx
Kind regards,
Henry
Yes indeed Henry. The use of a choke at the feed point does decouple the coax by providing a high impedance path on the braid to common mode currents on the coax. The difference in how effective radials accomplish this task is that they provide low impedance resonant elements to radiate these currents. This is why the 5/8 wave ground plane with real radials is known for low RFI even without a coax choke.
At 27.385MHz my Hy-Gain Penetrator at:
X = 0, 1:1 SWR = 274"
Average circumference - 2.5"
Unused .5"
of radiator below feed point for bolt hole strength
--> 274" + 2.5" - .5" = 276" electrical, at .999 velocity factor of air.
11811* ÷ 27.385 = 431.3" x .64 = 276"
*speed of light
Notice anything similar there? It's clearly a .64λ
In a day when everyone was touting the performance of the 5/8λ design, why would a company's advertisers be so obtuse as to offer anything else, except what was popular; a "5/8λ"?
Look at all the silly negative posts in
just the last 3 months about the Sirio Gain Master being just another snake-oil big stick, or another fiberglass POS, etc..., some even coming from intelligent Amateurs who should know better.
People tend to disbelieve and shy away from anything new while following the pack, and Hy-gain obviously knew it.
No one wants to be the guinea pig until someone else takes the risk first and proves it for them.
Just because Hy-Gain decided to name it a 5/8
λ or a 211/330λ or a blue flamingo doesn't change the physical or electrical properties, and it is a .64, like it or not.
I posted only a few of the .64λ Double Extended Zepp websites, there are many more, and each is specifically referring to a .64λ, even though some might not be quite intelligent enough to actually put 2 & 2 together and do their own calculating.
Some of those websites obviously used a velocity factor in their calculations but failed to mention it.
- I'll address that in more detail in my reply to SW.
If the radials were to cancel all of the bottom 1/8λ
inverse current they would certainly have to be mounted at a point 4.5' up the radiator, but as Shockwave already pointed out in his silly rant, and according to him that would not work.
If that's true, I imagine Hy-gain may have tried that and found that 4.5' wouldn't work, and that 2.25' wouldn't work, and that 1.125' wouldn't work, but that 11" would work so instead of bottom-mounting the radials as did many others, like A/S on their Jam Ram, Hy-gain chose to use them in an application which helped to both lower the TOA and add gain to their .64
λ Penetrator which they chose to call a "5/8λ", no doubt for marketing purposes.
The metal is there for all to see. The math is there for all to see.
The feed point is only .5" up from the bottom of the radiator, the RF gets to the upper radiator somehow, you tell me how they designed it to, miraculously, amazingly, mysteriously prevent the bottom 11" of RF from radiating without a canceling Vector basket or some other form of radiation prevention?
Just a wee sprinkle of some magic Shockwave-Faraday dust, perhaps?
Perhaps this will help to clarify why:
There is no inverse current in a bottom-fed ½
λ radiator.
Yeah, ok, well this snake oil "sentiment" measures .64λ not .625λ, and that's a 6.5" difference, enough to retune a Scottish CB 5/8λ from the center of the CB band to the center of the 10m Amateur band.
The Hy-gain Penetrator is 6.5" longer than the Sigma 5/8, the I-10K, the Wilson Alpha V-5/8 and the Sirio 827, however, it is the same length as the Radio Shack .64, Taylor GLR-4 .64 and the Wolf .64, all of which are proven performers, but must be a silly .64 waste if shockwave says so.
If adding 6.5" to an antenna just can't make a hoot of difference then let's see the Vector shortened or lengthened by 6.5" and not sacrifice it's perfection, since shockwave insists it must be so much better than the LW-150 from the 1980s
(which had it's lunch eaten by my Penetrator) due to Sirio's new 'precise measurements'.
Interesting how supposedly insignificant
a foot of radial relocation and more than ½ a foot of radiator length are a when it's not on his pet antenna, the LW-150 clone called the Vector 4000.
from your first link Scott, i'd seriously check out all the info on that site, as i've noticed a couple of innacuracies Such as? previously, before you take it as gospel, I didn't claim it is "Gospel" I used these four of many more websites where Amateurs utilize, mention or otherwise claim a .64, as an example of Shockwave's inaccuracy in information dissemination. Please recall it in context, Shockwave claimed Amateurs don't use .64, only dumb CBers do. the third link looks like its either been copied from the first or vice versa, the schematic of the double zepp is exactly the same in both,bit of plagerism going on there methinks. Yes, how about that, two agree and approve each other's specs. big deal, so what.
the other two links i don't even see .64 mentioned except from the lengths being the same as the other two sites, again makes me wonder which one is the true source. Do the math.
Why quote professionals? They simply buy coaxial J-poles like the one SW markets. Why would they want or need to know antenna theory?
- And I've already used the professionals of Hy-gain, Taylor, R/S and Eddie-Wolf who were manufacturers of a .64, isn't that enough?
HUH?? Sound theory???
Shockwave proposes something silly which won't work, then explains why his silly proposition won't work.
So the F#CK what?
Proves nothing
except Hy-gain didn't do this silly shockwave extendo-radial idea, but instead did do what DOES work.
Marconi, I agree that Hy-Gain moved the radials for a reason. They were moved the exact distance required to bolt the mast to the antenna without the mast being above the radials. It's all about proper decoupling and nothing more.
BULL$#!T! - As if it wouldn't "decouple" if the radials were at the bottom of the U-bracket with the mast parallel and behind the existing mounting bracket, just like the A/S Jam Ram.
Just another one of your Red Herrings.
The radials exist as a counterpoise to complete the sine wave, which also happens to help decouple the coax instead of it using the coax & mast for the counterpoise.
More effective decoupling is done by adding a CMC choke to the coax.
CDX, childishly yelling at me in large capitol font is never going to make me submit to your request. Assume whatever you want about the CST model. You have demonstrated little understanding of the information I've already shared here. I would prefer at this point you just assume it's a 1/2 wave J-Pole and I do not have the model in my possession.
Childishly blaming my lack of agreement with your unfounded 'theories' as reason to hide the CST from everyone doesn't make you look like anything other than the Charlatan and fraud I now believe you to be.
And I'm not yelling to "Make you" do anything, I'm showing the rest of the world just what a fraud I have come to believe you have made of yourself.
"Waaaah, You taunted me! Now I'm not going to let you play with my toys!!!"
...like THAT'S real mature.
No, you will NEVER show it because it clearly disproves your magic containment pseudo-collinear theory.
There could be a hundred people asking for it and you will NEVER let it be seen.
...I just wonder what your next excuse will be.
- Oh yeah, you've already used it. Tell me if I have it wrong:
You are a fraud and a liar, and when you said you had the full CST so you know it's at full bloom you actually didn't have it at all and truly have no way of actually knowing.
Is that what you meant when you wrote above that I should now go ahead and believe you don't have it?
Is that supposed to make it all go away?
Is that supposed to make people believe you actually do have it but won't show it because you want me to think you don't have it so you look like a liar, and that somehow justifies keeping it well hidden from everyone else?
...makes as much sense as the rest of your hooey.
Don't forget to read my signature, Shockwave.
Henry, you are following the debate correctly. The design of the mounting / radial bracket has made to keep the radials above the mast. Not to reduce the radiation in the lower 1/8 wave of the 5/8 wave main radiator as has been accomplished with the GM.
Henry, he has no way of knowing this to be true, he simply believes that if he states it as if it is fact everyone will believe him.
There is no need to keep radials above the mast, actually in his theory the lower the better, and as he stated, the RF will go to the ¼ radials anyway because they are a "Low impedance" resonant ¼ wave.
No, this is just another one of his
red herrings designed to throw you off into another direction so you'll believe that it simply cannot be as it clearly and obviously is.
Tnx Shockwave,!
Imagine yourself climbing in a pole with the antenna...or attaching the antenna on a pole against a chimney..
Your always below the antenna.
Im pritty sure its easier to attach the antenna when there are no radials in "the way".
Perhaps it is of a more practical reason instead of electrical?
Regards,
Henry
Anything but the obvious, huh?
The highest 20% of the inverse current portion of the radiator is 'under-ground' and that means
nothing?
Wait a minute, is this a CB forum or something?
Yeah, well he also mentions and it also shows .64 twice, so why don't you mention that?
Again you deftly and conveniently misrepresent the truth.
The author states "About 5/8" but you forgot to mention that he offers a graph with two very clear .64s written on it.
- And wasn't it you who stated in an earlier post that 'it's only fifteen hundredths different'.
"About 5/8" could easily be .64, especially when specifically mentioned that it is. Just more intentional misrepresentation.
Second link: Clearly shows the radiators are exactly 5/8 wave to those who know how to do the calculations. Oh, you mean that special group of elite few with your rare and mysterious knowledge?
- Well let's see if I know how:
88'2" = 1058"
.64 x 11811 ÷ 7.030 = 1075.25"
1075.25" x the average .98 velocity factor of wire = 1053.75
1053.75 is within 4.25" of his number,
now let's try it with your alleged .625:
.625 x 11811 ÷ 7.030 = 1050 x .98 (vf) = 1029.0" or almost SEVEN TIMES further away from his measurement than is the .64.
You lose again.
Please ask me to show you where I find .98 vf, I really enjoy posting lots of links.
Evidently you DON'Tknow how to do the "Calculations".
Clearly you don't realize that he is using more heavily insulated wire, just like what I used for my Quad and had to multiply clear down to a .95 velocity factor, and that same 95% velocity factor a couple of your
are always screaming about.
So, 11811 x .64 ÷ 14.2 = 532.3"
599 ÷ 14.2 = 42.18' or 506" ÷ .95 = 532.8"
How about that, within ½" at .64, looks like you're wrong for a 3rd time.
Fourth link: Congratulations! You found one member of some ham club who agrees with your .64 calculations. I can point you to a thousand articles written by more knowledgeable people who disagree. No you can't.
Congratulations, I clearly showed how misleading you are with your emphatic but absolutely wrong, BS-filled posts.
Hey Shock, remember not to miss my signature below.
007,
You quoted me in the above post. I want to retain the intended perspective of my post so the record remains clear.
I highlighted in red the portion of Shock's post to which my reply was directed. Furthemore, I referenced that portion as representing theory. I am careful to be as exact in my wording as I can. I do believe as I said that someone had finally answered a question with some theory. I believe the highlighted portion makes sense. Whether it applies in the case of the P500 is something you guys will have to work out.
Whether his suggestion in the rest of his post is good science is not my point in my post, and you guys are providing the entertainment portion of this thread, so carry on.
:pop:
:pop:
i've never heard .64 mentioned in any other radio/tv publication except for cb, which suggests to me its just another piece of bullshit hype marketing, most likely from dealers as from what i can see it definitely isn't being claimed by hy gain.
Hey George, here is something regarding .64 wavelength from back around 1924, when the idea was being considered for the US Broadcast Industry.
DID YOU KNOW . . . . . . . . ?
The vertical antenna referred to as the ”5/8 whip,” commonly used as a 2-meter mobile antenna was originally developed to fill a need for an efficient transmitting antenna in the AM broadcast band. The first broadcast antenna designs used a top loaded vertical type of antenna. Usually this vertical was lower that a ¼ wavelength and was supported from a number of top loading wires strung between two towers. There was no radiation from the horizontal top loading wires because of the canceling effects of opposing current flow.
Besides physical support, the horizontal wires served to electrically lengthen the vertical element as a means to bringing it near a quarter wavelength. This type of antenna structure certainly had its drawbacks. In areas where there was heavy ice loading, the large number of conductors and leverage on the supporting structures frequently caused severe damage. The radiation pattern was distorted by two supporting towers.
A paper published in the proceedings of the IRE, December 1924, “On the Optimum Transmitting Wavelength for a Vertical Antenna Over Perfect Earth” described the findings of Suart Ballantine. He had determined that a vertical radiator of 0.64 wavelength produced maximum radiation horizontally broadside to the antenna. In his paper, Ballantine calculated that in comparison to the zero gain of a quarter-wave vertical, the 0.64 wavelength antenna produced a gain of 3.03 dB.
One problem in the broadcast application became apparent with the first installations. Radiation from the higher angle minor lobe returned to ground from the ionosphere at night, and caused severe fading several miles from the transmitting point by interfering with ground wave major lobe. The solution was reduction in antenna height to 0.528 wavelength. Ballantine’s later developments in ground radial systems further improved the efficiency of broadcast vertical type antennas. To this day, despite the widespread shift to the FM band there are still thousands of AM broadcast stations using 190 degree towers.
Stuart Ballantine who was born in 1897, made many important contributions to the science of radio. In 1922 he wrote “Radio Telephone for Amateurs.” Fully indexed, it dealt with basic theory, vacuum tube theory, RF stages, various modulation methods systems and antenna systems. Published as a hard cover volume, it was a major treatise for its time and set a precedent for comprehensive radio publications that followed, such as ARRL’s “Radio Amateur’s
Charles Stuart Ballantine
Handbook launched four years later.
The author of this column has a hardback edition of Ballantine’s text that his father purchased in 1924. It is an intriguing insight into the state of technical advancement in that period, Ballantine’s extensive technical knowledge and his unique manner of presentation.
Ballantine had a very distinguished career. He was born in 1897 and by 1908 was an Amateur Radio enthusiast. He worked as a ship radio officer during the summers of 1913-15. After graduation from Drexel University, he began his engineering career with the US Navy and was instrumental in achieving several advancements in direction finding and developments in the loop compass.
After WW1 he attended Harvard and went on to foster many significant advances in the radio and audio field. He held more than thirty patents and was a Fellow of the American Physical Society, the Acoustical Society of America and the IRE. He received many prestigious awards from major organizations and the Franklin Institute named a medal in his honor.
Ballantine died in 1944 at the age
I still contend that the problem with the mis-interpretation of this study was overlooking the fact that the idea was over a perfect ground plane that extended out to infinity. Upon post-study testing this idea was later discounted because in the real world, "Mother Nature Rules," and the .64 produced a lobe pattern characteristic that was unfavorable when in use. The 5/8 wave solved the problem.
Source: http://www.maarc.ca/html/qtc_6-10.html
    boog351 has left the room.
