Been trying to get PSK31 going past 2 hrs with Digipan and Hamscope interface to my TenTec Omni VII all I get is gibberish. Need some help from the Pro's.
Using Rigblaster No mic used same setup on my 897D in the past no issues but now new PC and trying on another rig. I have the cables plugged in for transmit and audio. I can tx but just read gibberish on rx on 40 and 80 in the area their should be PSK31
It's been a long time since I've messed with 80 or 40 meter PSK31. One thing you might try is to switch from USB to LSB, or visa versa. Not sure what the convention is now, sorry 'bout that.
If the signal is too weak, it'll garble up a lot..
I use digipan...just find a signal with a lot of red, and click your mouse on it. It'll automatically center on the signal, and begin converting digital signal to text.
Also, make sure you're tuning to a PSK31 signal, and not something else...I spent 15 minutes trying to figure out why PSK wasn't translating correctly, then I realized, the mode I was trying to tune to was definitely not PSK.
Check your sound card settings.
The ft897, 857,817 are one of the easy set ups on digital modes....just remember to have the mode punched in as digital...
The American Radio Relay League (ARRL) is the national association for amateur radio, connecting hams around the U.S. with news, information and resources.
