Thanks for showing off your pics! I just restored a CTE LW150 with stronger tubing at the top. it works great too.
I'd like to see photos of you antenna.
As a matter of interest to those looking for a stout way to mount a gamma:
As for the bottom of the gamma, what you see there comes from making the mobile antennas.
For a person without a true fabrication facility getting a mobile antenna together was not too much
a problem, but finding a way to securely attach it to the mounting bracket was challenging. I tried
various things until I eventually landed on a combination of a brass compression fitting and the brass
reducing bushing. The pipe threads in the brass reducer are the same as those on a standard 3/8" fine
thread stud used with antennas except pipe thread tapers slightly. I use a 3/8" thread tap for bolts to
chase the threads straight. once done, I merely thread a bolt from the top side of the reducer bushing
into a standard mount, as you see it done in the photo. I migrated the same process over to the gamma
for use here, and that will likely be the manner of mounting all my gammas for all types antennas in the future.
Notice the bottom of the homebrew mobile. the bottom tube of one of these is what the gamma is (of proper length, of course).
The antenna has a propensity for being noisier than both the Astroplane and the 4el beam. It is very quiet without the preamp on, whereas the other two antennas handle preamp without added white noise. However, it seems to do well so far. Today's conditions are not very good into NW Arkansas, so I am still out with a verdict.
In spite of poor conditions I've managed a few contacts with unsolicited good comments on the other end not using a preamp. I will keep monitoring under various conditions, but the homebrew AP is tougher competition than many folks will admit.
I gave it some thought, but decided others I used this method on survived extremely high winds. They are self-drilling screws - #8BTW , you weren't concerned about , making a weak point at the verticals feed-point with the 6 bolts/screws going into it for the bottom basket elements ?
also , what is the washer looking part behind the 259 for ?
good to hear the noise issue isn't caused by the antenna .
BTW , do you use a choke under the feed-point ?
