ICOM IC-7000 programming cable help
Se7en
Well-Known Member
Jun 27, 2010
4,573
223
Ca
Where what and who do i buy the cable from i really don't want to spend more then $30.00 for it. i have read that its True china cables wont work with Ham radio delux. yes i have herd it is FALSE. so i need to know? i use the 7000 on the base i might as well interface it with my windows Vista and Fios.:thumbup:
Order it from Mama China.
You will be satisfied.
The ones that can't get it to work are usually computer stupid, get frustrated and cry about the cable.
I have one from RadioShack that I use for my IC-7000. It is Model #20-546, and cost $34.99, has a USB to 3.5mm connector (either stereo or mono via an adaptor jumper). The old version (20-047) came with a Driver CD, but the new one requires downloading from the Internet. Hope that helps.
73,
Mike
Thanks all. Im not pc dumb. All u have to do is fine the correct com port to communicate with the radio and pc. Ill buy the one from chickity china. I figured it was pcretarded people might just not get the concept. To the guy it is for ham radio deluxe. Might aswell use it with the new pc. I don't do digital rtty psk yet.
Sent from Outerspace, on the DarkSide of X.
After I bought a cable from China, I will never do that again. They said it was 6 ft long; it was only 3 ft long. Said it would work with my radio, it didn't. I bought one from 'Affordable Radio' for a few more bucks; but it was all that it claimed to be.
I recommend them:
6' USB CI-V CT-17 CAT Cable Icom IC-756 IC-7000 IC-7800 | eBay
What radio were u using it on ? Sometimes I get broken new stuff from china but there good at ems a replacement free of charge.
But was the cable made in China?
Hmm . . . can't rightly say . . .
The seller is out of Niagara Falls, NY. If he gets them from China - I can't say. But I can say that the cable arrived and worked as described. That works for me.
The first cable I ordered and then had to return - was ordered directly out of China thru eBay. That was a fiasco that I don't want to repeat nor would I want to see someone else make the same mistake that I did. Huge mess. Buy from 'Affordable Radio' on eBay and just save yerself the time and the trouble . . .
For about $10 you have what you need for programming and CIV control. This is what I use:
IC-7000 cable | eBay
You still need a sound card interface for digital modes...
The cable offered in those listings by suntekstore for $8.99 w/free shipping is the one I purchased and used prior to getting a RigBlaster Pro. It worked like a charm with no problems at all. Shipping took about 2 weeks, but I knew that prior to purchase so it wasn't a big deal to me.
i am about to purchase that one too. comes with that little driver CD. now it appears some cables have one black ring while others show 2 black rings.... that is interesting....? like one is mono while the others is stereo
    boog351 has left the room.
