First post and new Galaxy DX-979
Darkbeer
Feb 10, 2013
11
2
13
Hello folks, I am new here...just been lurking and trying to learn a little.
I drive a truck for a living. I just purchased a Galaxy DX-979 from Effingham Radio Repair on Ebay, the radio sounds great but I was wondering about the power levels.
I paid to have it peaked and tuned but it shows a little over 3 watts and swings to a bit over 6 watts.
I email the seller and was told that Galaxy radio's can't be tuned as high as other radio's.
I personally think I got the short end of the stick.
Any thoughts on this would be appreciated.
Thanks,
Darkbeer
Sounds like you got the Effing Tune, alright! There is no reason that rig should not put out at least 20 watts ssb, and about 15 swing on AM. Maybe more if it is a Mosfet final. You *can* turn it up yourself, but I leave that to the pro's. Read some posts here on who to send it to.
And welcome to the forum!
73,
RT307
73,
RT307
Thanks, that's kinda what I thought from the research I have done. And thanks for the welcome..
Thanks,
Darkbeer
What brand/model of meter did you use to gauge the output?
I have a Radio Shack swr/watt meter. It reads the same as the meter on the new Galaxy so I am thinking it is right. Also the readings are much different on my Cobra LX.
Are you driving an amp with it?
No amp. Straight out of the box. I have great swr and the radio sounds good. It just seems like the watt levels should be a bit higher.
I have a Galaxy 959 I did some trading for that has some much higher levels, I think it may have been tinkered with a bit...:)
Am I making too much out of this ? After what is called a Pro tune and peak shouldn't the radio at least show 4 watts ?
Darkbeer
Darkbeer
Check out that CBRadioMagazine link I posted. It shows the power levels normally associated with the 979
4 watts is your FCC approved legal "dead key".
You're not making too much out of this, you should be getting alot more than a 6 watt swing. 4 swinging to 16 is factory tune levels. (If the factory bothered to tune it right before they crammed it in a box and shipped it out to the nearest golden screwdriver.)
My 959 was severely choked with the factory tune with 3 watt deadkey and 12 watt swing along with 60% modulation. On SSB you had to yell to get it to swing 12 watts. I had DTB set it to a 1 watt lo and 4 watt hi deadkey with just under 100% modulation. SSB swings to 12 watts and 15 watts on a backwards whistle. Now everybody that hears me talk on it now loves the way it sounds
I'm not planning on sending anywhere at the present time, I was just wondering about the sellers statement that said "a cobra can be tuned to higher outputs then galaxy's".
That was his reason for low levels on my Galaxy.
Well,I've never owned a Cobra so I can't speak about that. I just know that a Galaxy has swing if you get it tuned and aligned right. I could have had DTB Radio tune it to what it can do safely(a whole lot higher)but opted to keep it a legal 4 watts deadkey. My 959 is a sweet radio.
