The two models below are center fed dipoles with a mast attached. One is at 36’ feet to the feed point, and the other at 40.5’ feet.
I also show these same antennas without a mast, because this is what we generally have presented in books and reports we see. This may be why we read W8JI always complaining about the shortcomings of modeling without a mast.
The importance of my approach here is done because the models without a mast show the antenna currents are almost perfectly balanced at all heights. However, in the real world when we add a mast, this perfect looking balance we see tends to go away at some heights. My Eznec models suggest to me that random heights above Earth show a far different CMC response in most cases than we see when installed at wavelength heights or multiples. So, I figure height may be important to consider for this issue.
Keep and eye on the red line current indicators.
I follow the assumptions noted in bold below:
We understand that the magnitude of currents, flowing on the outside of a mast or feed line, primarily develop due to a lack of current balance (imbalance) at the feed point.
So, as the difference in space between the red lines noted in the Eznec models and the elements increases, so is the magnitude of the common mode currents (CMC) increasing.
There are generally many segments in the wires of an Eznec model. Each segment is calculated as to its current value by the software, and these values/phase are noted in the tabular Currents Log.
For this report I make note of the space between the red lines and the elements as an indication of the magnitude. As the current magnitude differences increase at the feed point, so does the common mode current results. As the results increase, so can the issues associated with CMC, such as TVI, RFI, skewing of the antenna pattern, and changes in the performance noted. IMO however, common mode currents are not always a bad actor. Our antennas would not work without this RF characteristic, so in some cases such currents can be beneficial. This may be the reason many manufactures ignore the issue.
The goal of this thread is to suggest that antenna feed point height may largely be a deciding factor in how common mode currents manifest on the mast or feed line in our antenna installations, and thus the possible problems they can cause or not…to the pattern and performance.
So height should be considered if you see CMC problems, and this idea may suggest that a small change in height may help mitigate the problem somewhat. I have seen such changes regarding the CMC responses I saw in my shack, but unfortunately I have never tested the idea to a conclusion. I did have a feeling that something was afoot however.
View attachment Eznec and CMC's.pdf
I have also included two models of a 5/8 wave antenna to compare using this same idea about height.
