Here is my effort to model the SP500 with the matching device, and it is not easy to figure all those little angles and small wire lengths in that simple looking wire matching device.
The angles might
NOT be right on the money, but this was as close as I could get with the info I had. If you see something that does not look right, help me out and let me know, OK?
This antenna has a very bad match without the matching device, something over 100:1 SWR. With my matcher attached it shows a match of 7.0:1 SWR with stock lengths, and I think it is close to 27.205 mhz...but I can't be sure. I'm just going by dimensions I've gotten from a couple of members that responded to my request for measurements. I had to modify the overall length that I used, 266.5" inches for the stock at 27.205 mhz, out to 285.6" to find resonance and a low SWR however, and that too was based on reports about possible resonance from others.
This is not what I expected and it not right...so the model still needs some work IMO.
With my first attempt at this antenna it really
does not look like it is anything special. I have to make the radiator longer than specs called for, and that appears to lower the gain. It wasn't even close, and I was really surprised. I may find some little fix that will make it better, but I've spent about 5 hours on this one, and here is why this one is so difficult.
The following is the wires data entry report:
View attachment SP500 Wires Data.pdf
Like I noted earlier...this one is not easy.
1. I post a model without any matcher and it is nothing to get excited about either. This is in spite of the fact that I've never found much improvement with any other model I've done that required a matcher...one that I could duplicate as being in series with the radiator.
2. I also made another model with my idea for the physical matching device as best I could...using dimensions given me by others. I did not make the matcher curved around the radial bracket at the top like the SP500 does, but I don't it having square corners would make a big difference.
3. I tuned #2 model by making the antenna longer, just as noted by the instructions given, being the only modification to tune the SP500. I also did not use tapper in the elements, so I averaged the elements diameters between .50" and .75" with the top hat set at #12 gauge wire. These iterations did made a little difference, but they were only proportional to the differences we might expect, and that ain't much.
None of these three Eznec SP500 models even showed an advantage over a simple 1/4 wave ground plane Eznec model. This pretty much blew my mind. Typically, I don't see my models produce much advantage over the other CB models I've made, but they don't look much worse either...even though I suspect there is a very large group out there that will disagree bitterly with me on that idea.
Many years ago I had a new HyGain CLR2, that I thought was a great antenna. It did so much better that the mobiles that I had been running. I was impressed that I could talk for 30 miles and more in all directions around the local area with a stock CB radio and using AM only. But, after I got my first Starduster antenna up to 60' feet to the hub...that old CLR2 went into the materials stack to be used later to build my 4 element yagi beam. I couldn't put my finger on why that big old 5/8 wave with its radials 1" foot up the radiator didn't come up to par to my SD'r, but I had the thought it had something to do with the radials arangement...which I didn't believe looked right.
I often see in my modeling that radials tend to push RF up when added to my antennas...even when radials are absolutely necessary...as with some 5/8 wave models.
So, in a bit I'll remove the radials on this HyGain and place them down where I think they belong, and we'll see what Eznec suggest on this topic.
I also added a closeup of the Penetrator's matching device so some that care and will check it out, might see it you can help me realize a possible mistake. Something is causing this antenna to require me to make it so much longer than it should be at 27.205 mhz or close. I also added a few notes for the dimensions that I used, and I added a take-off on dimensions I used for the matcher I see in the manual as well. I anybody knows some better dimensions for these two matching wires...let me know.
