OVER 130% MODULATION!!!
This is Midland's version of the GE Superbase. Exact same board in both radios, the "double-sided" PLL02A SSB chassis. Stay away from these like the plague unless you're just going to buy the radio for AM use only, or to put on the shelf as a collector's item. I've had several of these and the GE Superbase models come across my bench, all with the same issue, SSB problems. Some had no TX/RX, like this one, other has problems with SSB "bouncing frequency" under modulation. They look neat, but unfortunately, their performance is less than spectacular. :(
~Cheers~
Stay away from these like the plague unless you're just going to buy the radio for AM use only, or to put on the shelf as a collector's item. ~Cheers~
Most of the problems with these sets center around the connectors between the 2 boards. Assembly/disassembly stresses the connecting pins (and there are so many of the damn things) causing solder fractures everywhere. Now that these sets are 30+ years old, the connectors themselves are becoming a problem.
- 399
That is true but what so many people overlook is that it is going to require a reasonable degree of negative peak compression (and filtering after that stage) in order to prevent those 130% negative peaks from hitting RF cutoff. Without that I'll probably hear the signal several channels away if it has any strength to it.
True, but I think there is a lot of confusion over negative peak compression and positive peak expansion. NPC is used broadly as a blanket statement when I think PPE fits better in most cases.
Reactions: 2 people
