Thanks for this. I opened up the mic , and thought, I have no idea what I am doing and then closed it up again.Looked a tad brittle in there. There was a hole through the little circuit board and I take it that may have been access to the adjuster??? I wonder if someone has done a vid of the mic gain adjusting from within the mic.
cheers
Bruce
i have adjusted mine . there will be a screw adjustment in mike similiar to a d104 mike
turn it 1 direction its all way down or off.
turn it other direction its maxed out. pretty simple.
right. wrong i found myself constantly adjusting this when using my amp with radio
so i cranked this up all the way then just used mic gain on radio to fine tune
for a after market mike hook it up on the right side its a simple 4 pin i recommend
the workman 502b mic its also a eletrec condencor mike same as stock mike
d104 sounds too tiny or pinched tuners sounded good if ya can find one
