Best all band new radio 1500.00 base type ?
May 10, 2014
24
4
13
My ham test date is closing in, I have been passing the test tests for a tec test, and am studying the general,I am looking for an all band that could also do 11 meter,with a kit or something . I would like a really good quite receive . And a good S meter.
My 2970-n2 is staticky ? But has great audio.......
Good for you and good luck.
Radios, here is my thoughts, Kenwood TS 2000 (S or X), then Icom IC 7100 / 9100, then Yaseu 857D.
I have used the 857D during a few contests, fieldday ect and was not overly impressed with the small display, menus. I have played with a 2000 and the 9100 and liked the 2000 the best.
Just my 2 cents.
Flex radio is new to me
That looks really neat ,I have a spare hot rod computer , but I would need it with
11 meter also,software is hard to work around with a jumper ?
Are you looking for a rig that covers 2, 440, 6 and HF? If you are I will seriously try and talk you out of that. My reason is while the shack in a box rigs are nice if you have a problem and need to send it out for repair you are down everything. Just something to think about. Congrats on being a ham.
P.s. your a ham now why jeopardize your license by running 11 meters with it. If you still want 11 meters buy a CB.
Reactions: 3 people
I've owned just about all the radios mentioned so far. My next rig is definitely going to be the Yaesu FT-DX1200 or the DX3000 if I wanted to spend the money. They engineer the same receiver into the 1200 as their top end rig. After using the FT-950 I won't buy another Kenwood. Icom would be my second choice.
Pick up a seperate rig for 2m/70cm. I'm not impressed with Yaesu rigs there but Icom makes some nice uhf/vhf rigs.
Just my opinion. :)
The broken radio
All in one can be a problem ,I work on digital printers and copiers w that have fax and scan to file and when the feeder doesn't work,all there stuff get backed up And the whole office is helpless.
Good point.
Good point.
Well now, that's a different story.
My thoughts, TS-480 HX and an Icom uhf/vhf. I personally don't have any use for uhf as it is not very active in my area. I don't really have too much experience with Kenwood vhf radios. I have had a few Icoms, great vhf radios. I have a close friend who has Yaseu and I find his to have a small knobs ect.
Just my $.02 here... you're a new ham why not look at some used/new HF only gear? The ICOM 718 is a great started rig as is the Alinco Sr8T. VHF only radios are a dime a dozen out there. In the long run you will much better off, take the extra cash and spend it on the most important part..... the antennas!
