Marconi, the only way I know to tell if your model gets the phase correctly is the use of my 4 wire test. I don't believe anyone has corrected that problem yet. I think DB has done similar experiments in EZNEC to attempt to correct this phase and was able to show decent gain in his latest model. Unfortunately he still confirmed EZNEC only worked when the collinear model used a 180 degree phase delay in total contradiction to all field tests.
Donald, I've responded to your comments above already, but I want to respond another way...by relating to your 4 wire test.
When I did my model of this collinear stacking idea of yours, I had to guess at exactly how and what you did. It is true that you gave me a sketchy idea, but I asked you for better details, or an Eznec model of the project that you did. I feel you had to have an Eznec model, else how would you know that Eznec did not accurately produce the results...you claim to see in your field testing work.
If DB did some similar work as you mention...it never came to my attention either. I have asked DB to share with me his S4/NV4K model in this regard or just show me his results. I'm still waiting. I have no idea what DB's S4/NV4K even looks like or if he bothered to model with any of the limitations I called to his attention...that I deem essential using Eznec, and possibly 4Ne2 as well. I've mentioned these limitations several times here on WWDX. IMO, using NEC2 we must consider them too or else the model will suffer and not show currents correctly, and I wonder if DB's Average Gain results could be off. I find in such cases the model tends to show a bit more gain.
DB, if you read this, could you please tell me what the Average Gain result was for your S4/NV4K model, the one where Donald says above...that you got some positive results showing increased gain.
In the rare event you are able to get EZNEC to model a Sigma, you have the information to confirm it yourself now that I've explained it. I can't tell without adding the 4 wires. You need to run that test on your own model. When you can stretch the 3 wire folded phasing section out in a straight line and it measures close to a 1/4 wavelength over its ENTIRE conductor length, you will be the first ever to make EZNEC work with the Sigma.
Except for what you tell us Donald, I'm not sure what your test is supposed to demonstrate. In Booty Monsters eHam thread on his Vector build...you discussed this 4 wire collinear test using the S4/NV4K and adding a 1/2 wave radiator above it, but as I recall nobody even commented on the idea. I don't know why that happened as it did either. It could be nobody understood, or maybe they figured the idea was a dubious comparison.
Since the shorted phasing stub in the J-pole example is known as a "1/4 wave stub" even though it produces a 180 degree phase shift and has a conductor length of 1/2 wave, I will no longer refer to this type of phase delay by its insensible wavelength name since it's misleading, confusing and not accurate. I think it's inappropriate to name a phase delay based on its physical length AFTER the conductor is folded in half rather than to name it based on the actual amount of shift in wavelength or phase it produces.
This is confusing to me as well, and since there are arguments going on about how and what constitutes this collinear phasing business...I'm not convinced of its validity as a test, but I do hear what you are saying about it. All I really know is I think the S4 design is basically a raised up 1/2 waver radiator, so I stacked the model using a 1/2 wave long phasing harness to set the current phase equal in both 1/2 wave radiators, and it worked just as expected. I wasn't surprised.
Just a correction Donald, it was 4NEC2, not EZNEC. They are based on the same engine, but I'm not sure if EZNEC uses a modified NEC2 or if it is stock.
I have played with EZNEC some, the layout of EZNEC just seemed un-intuitive to me... With 4NEC2 I was able to essentially jump right in.
DB, after many previous tries at working with Eznec, I finally found it just as you noted with your using 4Nec2...I was able to essentially jump right in.
