Do you add the length whip that works for your particular installation and then see where the taps put you frequency wise or is there an optimum length? The whip they show with the complete kit looks like a stick antenna of some kind.
I have seen some references to running an add on coil with a 102" whip, along with a tuner. I can't find much on the web about this, though. Where do you get the coil, and is it a worthwhile setup?
