Standoff for a 80-20m dipole ?...
There is an eBay seller that has good deals on dacron rope. I think it's the hamstore or something like that.
For a pulley to raise mine up the mast I just used a solid steel ring from home depot welded to an L bracket held to the mast with hose clamps. The ring is more reliable than a pulley. With a pulley the roller can rust up and the rope can jump out of the groove. The rope loops through the ring and I pull the antenna up like a flag.
The bracket is just flat steel from home depot
Reactions: Oatmeal
Ok, yeah been looking for Dacron rope, but don't think I'll use a pulley either, going to something else....
That dang weed eater string has been doing good, lol....
I finally got around to taking a pic of the stand-off I made. It's just a piece of aluminum L bracket, a fiberglass rod and a couple of U-bolts. Originally I had a piece of wood painted black, but that didn't last long in the sun.
Reactions: Oatmeal
I finally got around to taking a pic of the stand-off I made. It's just a piece of aluminum L bracket, a fiberglass rod and a couple of U-bolts. Originally I had a piece of wood painted black, but that didn't last long in the sun.View attachment 16501
Call me stupid but I finally know what you guys are talking about. To me a stand-off is short and is used to keep feedline spaced a few inches from a mast. That is what it has always meant in radio-speak going back about 100 years or so. What we are talking about here is a dog leg or yard arm. :)
Reactions: RatsoW8 and binrat
Right. When I say semantics I am referring to the meaning or interpretation of a word. Thank you for the supporting evidence.
http://www.thefreedictionary.com/semantics
I guess you missed the comparison to "You say potato, I say po-tah-toe" when I said "You call it semantics. I call it proper terminology". Thank you for showing us that even you can miss the obvious. :)
  • @ AWP:
  • @ wavrider:
    sea que sea que,
