Why would that mean no ground plane? If I have my riser grounded to my chassis what does it matter?
The ground plane starts where the coax braid ends, not two or three feet away. Its all about the amount of metal DIRECTLY UNDER THE ANTENNA STARTING WHERE THE BRAID ENDS and you have none, well to the antenna you have a circle or square the horizontal area of the riser. Sure it may meter real well with your ohm meter but that's DC and RF is AC and to get a true indication of impedance it needs to be measured at the frequency its being used on. The only thing using an Ohm meter achieves when it comes to antennas is to tell you there's a connection. They cannot tell you how good that is for RF in any way, shape or form. They are in effect about as much use as a chocolate fireguard. They will for example show a dead short on an antenna socket with an antenna that is DC grounded yet to RF that dead short is invisible and doesn't exist.
If you think it works great then stick a 1/4 wave whip on the mount, get an antenna analyser and measure what the value of the impedance is at resonance. Anything other than 36.8 Ohms means there are losses.
And for the second time im not cophasing the two antennas. There's only gonna be one hot antenna in this setup with the second in the rear to block the backdoor so I dont need 9 ft.....I only need between 6 and 7.
The one not being used will be parasitic. A lot of the current flowing out of the hot antenna will end up flowing in the one not being used.
On a 4 square array antennas are spaced 1/4 wavelength apart to give the best gain AND DIRECTIVITY. No point having tons of gain if its not going where you want.
Ultimately given how much better a properly installed antenna would work compared to both the piss poor install you have and the even poorer one you're planning, putting two antennas on would be both a waste of time and money.
