President Antenna's
Not sure if they are out yet. They are coming, but haven't seen a release date yet. I could be wrong, but they have some radios coming out as well. I suppose they'll release the antennas around the same time. The TX antenna looks promising.
Reactions: rabbiporkchop
Some interesting design on a couple of these models.
Some good; some not so.
The good? The Iowa version uses two rings to change the coil inductance, just like the Imax 2000 or the A99 antenna uses. No need to trim the whip to get the right match. Speaking of the whip, I am no fan of antennas that use a whip of 40 inches/less, as they tend to be very narrow banded. Mobile antenna are already compromised and offer no gain.
On the Alabama version, the center section is made of clear plastic. So long as that plastic has been ultraviolet stabilized, that would be OK. If not; then mechanical failure/breakage is inevitable within a few short years. Doesn't use the ring method for tuning as the Iowa version does. Does use a 60 inch long whip - comparable to a Wilson 1000/5000. Whips that are 5 ft or longer seem to have decent efficiency and have better bandwidth than the 40 inch antennas, so this one a clear step up from the first one.
Now, the Maryland version uses a 57 inch whip AND the tuning ring like the Iowa version does. It doesn't use clear plastic on the base either. So far, that looks like the best choice.
The bad? The Mississippi version just sucks - IMO. Short antenna whip that uses both a center load and base coil. Only 28 inches in height; uh oh. The worst antenna so far and a real loser because of the low efficiency and very narrow banded design. Wonder if it can make the standard 40 CB channels with an acceptable SWR . . . doubtful . . .
The Texas version is the real winner in this lineup that I can see. The whip is a whopping 83 inches tall, making the need for the coil to be minimal to reach the proper impedance and therefore offers the least loss of all the aforementioned antennas. Very wide banded and very efficient design. No mention of thickness of the whip, as a thin gauge whip will be anything but perpendicular at even low vehicle speeds - and therefore have a poor radiating pattern.
What I dislike about all of them is that they just use the 3/8" screw base instead of using a SO-239 like a Wilson or a Sirio does. Limits one to use their mag base or some cheap off the shelf job that may not be stable when the vehicle reaches freeway speeds in a headwind.
What I like about them is that the whip material is a cheap stainless steel. Better a cheap stainless than no stainless at all.
But this is all I can gather from what can be seen in the pictures provided . . . just thought I would stir the pot a little . . .
The Mississippi version looks like it was designed more to look impressive in the truck stop store than to sound impressive on the air, seems gimmicky to me.
Texas says it's a 7/8 wave, can this work or is it just marketing BS?
If the quality is there the Maryland and Iowa seem to have potential.
The Maryland claims 2000 KHz bandwidth, That I would like to see.
Notice they don't print the actual frequency range tested in that bandwidth in the antennas SWR curve.
I see new fancy designs in an attempt to re-invent the wheel.
Disregard what Robb says about 3/8 stud mounts.
3/8 stud mounts on mobile antennas have been around for decades and unless you put them on hand tight, you are not likely to lose it. I been using them for decades myself with all kinds of mobile antennas and yet to have lost one.
I'm currently using a Hustler tri-band series which is 3 large resonator coils on a 24 in. mast all with 3/8 stud mounts on a semi-truck driving over 3000 miles a week with rough roads and high winds and all kinds of weather with no problems.
This is what I'm currently using only with even larger coils.
main.php
If your in the market for a good mobile antenna now, go with the Sirio 5000 series.
on british cb site from a year ago,,, guy complains he cant get a president virginia to set for the cept band there which is our 40 channels plus thier 40 (80),,,, says he cant trim or add on and wished he got something else
main.php
Yeah, I know that truckers use this format and others use the 3/8 stud design with a puck, big whoop.
My comment was to point out to others/non-truckers that Sirio and Wilson use the SO-239 when using a mag mount, and they offer nothing in that regard. That's all . . .
Reactions: undertaker
My comment was to point out to others/non-truckers that Sirio and Wilson use the SO-239 when using a mag mount, and they offer nothing in that regard. and that proves there is nothing wrong with 3/8 stud mounts at all....That's all . . .
Big woop? people who know better and are experienced in mobile antennas use this mounting format for a reason. Obviously you lack much of any mobile experience.
You initially said
" What I dislike about all of them is that they just use the 3/8" screw base instead of using a SO-239 like a Wilson What I dislike about all of them is that they just use the 3/8" screw base instead of using a SO-239 like a Wilson"
That is implying that these antennas with 3/8 studs have limitations, wrong! There are far more and better mounting options with 3/8 studs then having a SO 239 terminus. That's a Fact!
You also said,
"Limits one to use their mag base or some cheap off the shelf job that may not be stable when the vehicle reaches freeway speeds in a headwind"
Ridiculous,
Again having to be limited to stud mount applications to you is like downgrading to having to use an old rotary dial phone.
M0GVZ and many others recommend Breedlove puck mounts which seem to be the best quality mounts around and nearly all accept 3/8 x 24 studs and your "big woop" comment is directed at those.
Once again you are trying to put a spin on everything you say wrong to try and save face.
Reactions: Slowmover
