#40 Shop Talk - Wafer switch cleaning tips
Radio Tech
Radio Operator
Sep 9, 2008
858
312
173
65
North Carolina
www.gokarters.com
Last video posting for a while guys. Don't want to be boring folks and don't want my videos to be the only thing I post here. Those that follow can find them on my YouTube channel.
Thanks for watching.
In this video we look at several types of wafer switches. We then look at a method I use to clean these switches and bring them back to life. These switches are in many types of equipment. Lets look at what we can do to repair these.
Another good video Buddy. A lot of folks have no idea how to properly maintain ceramic RF switches. A friend of mine had a silver plated ceramic RF switch very similar to the one in your video and he used 800 or 1000 grit wet sandpaper to burnish the contacts to get rid of the oxidization. The problem was he was a little too aggressive with it and completely removed the silver plating in several places taking it right down to the brass base metal. This lead to even more problems with poor contacts and arcing until eventually the switch self destructed in a flash of sparks. I have access to some metal cleaning chemicals at work that I use (we use a LOT of stainless steel, bronze/brass, and aluminum) but may look into the salt/vinegar since the stuff from work is not exactly skin friendly. LOL
Good video!
Recently I picked up a pretty wasted looking crystal switch for a DX60B. The rig it came from was in a fire from what I could tell. I took it apart, soaked it in vinegar and used a soft toothbrush on it. I was surprised it came out as well as it did. Things are often not as bad as they seem!
Vinegar on a cotton swab is also good for removing battery corrosion from battery compartments.
Reactions: 2RT307
Good video thanks for posting !
Thanks for watching. :)
Thanks CK.
I hate it when some ones brings a device in where they have used a file or sand paper to clean contacts. Makes me cringe.
Sanded the sliver coating right off eh? Shows how uneducated folks are. My job is try and spread the information around so folks will see there is a better way to do things.
Nothing wrong with chemicals to do this. Other than cost and health risk, there is some good stuff out there. Then you have to dispose of it.
Good thing about the solution I used in the video. It is harmless and easy to get rid of, plus it only cost pennies. And you saw how good of a job it did. I showed my brother just today how to clean some old pennies he found metal detecting. Made them look almost new.
Was thinking about limiting my video postings on websites. Since I started this channel it seems I am always busy and really limits my time to just get on forums and post other stuff. I get hundreds of messages a week now and it takes a lot of time.
Don't want folks to think I am only here to promote my YouTube channel.
Reactions: 2RT307
Good video!
Thanks and good deal. Now add a little salt to that vinegar and that will give it a chemical reaction. Does the scrubbing for you.
Thanks for sharing, switch looks good.
Reactions: 2RT307
