Hey guys, have a question....
Which position will the G5RV perform better in the Horz, or Vert position?...
Please define perform....
All the Best
Gary![]()
Not really enough information to make an informed decision .
So ok !assuming 20m at 32 ft high.
.No feedline radiation ( that can be a real bitch on a g5rv)
. The antenna is in the clear and is orientated the correct way.
The horizontal will be a much quieter antenna and will work very well.
However the vertical case!.
.First .How do you get a 100 ft +g5rv mounted vertical and keep the feeder perpendicular for at least 1/4 wave.? Then to keep ground losses low you want the feed point around 1 wave length high . That would also keep the bottom wire off the ground So we are now talking at least 110 ft high.
Now that would be a truly awesome vertical and I think signal wise it would out perform the horizontal but with a higher noise floor.
If noise is the major problem you really need to consider a loop.
After rereading the thread (post 7 and 8) I can't decide if he is truly trying to hang it vertical or if he means inverted V. I think he deleted the post about polarity and left anyway.
