Hustler Trumpet 27-T Colinear Base Station Antenna
Unit 194
Well-Known Member
Feb 25, 2006
1,233
380
93
New Jersey
Anybody ever own or know anything about this .64 wavelength omni base station antenna?
I think it's similar to the Hustler "Super Swamper" antenna.
This antenna is not listed at CB Tricks and a Google search was fruitless. I guess this must be an oddball antenna from the 70s with very low production numbers.
It should be a standard 5/8 in length. Try setting the length to about 22' 4" from the top of the radial plate or the top of the mounting bracket and see if that doesn't get you a flat SWR.
Radials should be about 8' 10".
Reactions: Unit 194
