75 OHM COAX W/PL259
doctor
Supporting Member
Aug 1, 2006
1,036
80
58
83
indiana
ANYONE know where to purchase 25 foot length of 75 ohm coax with pl259 on both ends.
TNX
DOCTOR 795
Actually I have been thinking about going to crimp type connectors. Not the cheap ones but the good quality types with the proper crimp tool. Commercial users and thousands of hobbyists use them with no issues whatsoever. They DID have a bad reputation many years ago but crimp tools and techniques have come a long way since then.
look to ebay, some amateur in Arkansas has adapters for sale, I am using them and no issues so far
what flavor 75ohm coax? if its RG-6 you can get a 500' spool for about $40 and the kit to use the compression F-connectors then just use the F-to PL-259 adapters, I have a couple antenna's ran like this and they work fine
Reactions: wavrider
OK guys. Where do you get these crimp connectors, I knew they were not good many years ago, but maybe they have come along a lot better.
DOCTOR/795
The new style should be silver teflon and the center pin hole should be open just like the typical solder type.
The old ones are easy to spot, they have a small pin hole opening that's useless.
Be sure to invest in the ratcheting type crimpers with dies for the coax type or types you use.
You can buy them here along with the crimpers.
http://qsradio.com/phone/shop-now.html#!/PL-259-UHF-Male/c/11543085/offset=0&sort=normal
The right tools gets the job done right.
Reactions: Captain Kilowatt
Here is a good example of what to look for with Solder/crimp PL-259's
This below is what you want. You can see the center pin is large enough to push thru a tinned center conductor to be soldered.
This is the type you don't want. Notice the pin hole for the center conductor and this will not allow a tinned wire thru it. I argued about these types before because I believe they are a center crimp because how are you supposed to properly solder the center conductor?
That bottom image looks like it is for RG-58 with the single strand solid center conductor in which case it is the proper connector. You just crimp the tip or solder it.
