That's because all the pre made coax are made in Canada…My home grown cables are soldered better than store bought cabes.
Here is a good example of what to look for with Solder/crimp PL-259's
This below is what you want. You can see the center pin is large enough to push thru a tinned center conductor to be soldered.
This is the type you don't want. Notice the pin hole for the center conductor and this will not allow a tinned wire thru it. I argued about these types before because I believe they are a center crimp because how are you supposed to properly solder the center conductor?
