HF CONTEST RULES 17/18 Dec 2016
binrat
WDX Club Coordinator
Staff member
Nov 5, 2008
2,630
1,560
173
The Great White north
Gang.
Her are the rules for the contest. Any questions post up please.
Only contacts with other FORUM members count in the contest. The W9WDX roster maybe found as a sticky thread located here http://www.worldwidedx.com/threads/club-member-roster.132229/
-Frequency: HF 80 / 40 / 20 / 10. Daytime bands 10/20, nighttime 40/80 metres. For frequencies, forum frequencies 10 meters: 28.455 ( + ), 20 meters: 14.322 ( + ).
-Date/Time: 0001 17 - 2359 18 Dec 2016 UTC. If you're not sure how UTC time works, check here http://www.timeanddate.com/worldclock/converter.html?p1=3875
-Contacts: Contact logs may be in any format but it must be deciphered by common programs and must be posted in theW9WDX Contest Logs located here http://www.worldwidedx.com/forums/w9wdx-contest-logs.193/
Create only one thread for your contacts. You can edit or reply to your own thread, using it as your log throughout the contest (if you wish). The format is attached as an Excel file. It may be an excel attachment OR pasted into your thread.
At the end of the contest (+3 hours), the contacts forum will be locked, so make sure you upload all of your contacts before the end date/time.
Contacts will be verified against each others' logs, non confirmed contacts will not be counted.
-Multipliers: 2x multiplier for mobile, portable, or maritime contacts.
3x multiplier for any contacts outside of CONUS and Canada.
4x multiplier for QRP. For this contest QRP is 10 watts or less.
-If you operate as mobile, maritime, or portable during the contest, you will be credited with the multiplier for any contacts you make. If you operate as a base, you receive a multiplier for any contact you make with a mobile, portable, or maritime contact. Make sure you clearly designate these in your log
-Power limit: Maximum allowable according to your ticket.
-This is an "on your honor" contest and intended to be fun. Please play by the rules
- BE A COURTEOUS OPERATOR, PROMOTE THE SITE, AND MOST IMPORTANTLY HAVE FUN!
Reactions: camaro1
How about designating a 40m frequency? Also, how do others feel about using the site chatroom to help coordinate freq's / skeds?
I think yes, as long as you are not jumping from band to band back to back. To me back to back on different bands takes away the spirit of the contest.
I take it you do not have a Democrat party in Canada?
Vote early vote often Democratic motto.
Sort of like contact early and often.
Reactions: binrat
Gentlemen.
Since there are contacts recorded everywhere, please post up your contacts here.
At least I got one while QRP.
KK6USY Chuck Dec 18 1753 Z 14.322 5.5 jumping to 5.7
Reactions: wavrider
camaro1 (KD9CKB) ---- B J radionut (W9FNB) ------- 3.865mhz-------09:36 dec17 UTC----
camaro1 (KD9CKB) -----B J radionut (W9FNB) ------- 7.230mhz-------15:28 dec17 UTC----
camaro1 (KD9CKB) ---- Firerunner (Kk6USY) ------ 14.322mhz------ 16:08 dec17 UTC----
camaro1 (KD9CKB) -----Tallman (KW4YJ) ------ 7.205mhz-------17:59 dec17 UTC----
camaro1 (KD9CKB) -----Aussie (W4OZZ) ------ 14.340mhz-------19:21 dec17 UTC----
12-17-16 Chuck KK6USY
00:10... 14.250... W6GRD- GROVER/ TBA- CALIFORNIA
00:53... 7.208... W9FNB- GARY/ BJRADIONUT- INDIANA
16:00... 14.322... W9FNB- GARY/ BJRADIONUT- INDIANA / SECOND BAND
1608... 14322... KD9CKB- JAY/ CAMARO- WISCONSIN
18:45... 7.205.... K5KNM - ANDREW / fourstringburn N.M.
18:50... 7.205.... W6GRD - GROVER/TBA CA. SECOND BAND
19:22... 14.340...W40ZZ - PETER/ AUSSIE FLORIDA
12-18-16
09:04... 3.865... W8WAM-- ROBIN / OHIO
09:05... 3.865... N9FNB --- GARY / BJRADIONUT-INDIANA 3RD BAND
09:57... 3.865... N9CED--- CHARLES / N9CED - INDIANA
17:53... 14.322...VE6VID..Malen / Binrat Canada @10watts, FR at 70watts
