I might just scratch the building idea. Thanks for the reply. I appreciate it.I only know, because I keep getting so called newer builders amps in and they are not even close. Had to redo circuits and figure out designs for each.
Grab a pair of matched non-red dot Toshibas @I might just scratch the building idea. Thanks for the reply. I appreciate it.
What does the red dot stand for? And matched? I see that all the time.Grab a pair of matched non-red dot Toshibas @
$129.90
[RFpartsDOTcom], build your self a 2-pill?
This way you will be 95% there with just the old-school blue-print!
That's a pretty good chunk of coin just for the transistors, I imagine building an amp from the ground up will be very costly and time consuming, but ultimately a very rewarding experience!
I see the BLF188XR selling for 185$, and it has huge output power compared to two 2879's.
Thanks for that info.Red Dots were a later version that conformed to RoHS Eurotrash requirements of No-Lead. I understand they may not take high temperatures as well as the non-Red Dot Toshibas.
From RF Parts:
" The following information applies only to the Toshiba 2SC2879 & 2SC2979A.
Early design Toshiba 2SC2879 do not have the small red dot on the package (lower right). In contrast, the later “A” version has the dot to identify that it uses a
different insulator between the chip and the flange base.
The 2SC2879A meets all specifications on the Toshiba Data Sheet, however, we believe
the heat conductivity from chip to flange with the original 2SC2879 part is better.
Also, we found that the 2SC2879 had a bit higher Collector to Base breakdown voltage,
which would be of interest it the transistor was to be pushed beyond factory specs."
Matched means they hopefully have been checked for similar gain specs.
Knock on wood...I've never had a Toshiba 2sc2290 or 2sc2879 transistor fail. Red dot or not.
Keep in mind that is when they were run within or just slightly above their design parameters and keeping IMD (distortion/ harmonics) within acceptable low levels![]()
I have been saying that for a couple of years now.Grab a pair of matched non-red dot Toshibas @
$129.90
