Went nuts part deaux, the dousherry got the better of me and I went ahead and removed the tiny jumper using a fat mashed up tip soldering iron. I just couldn't wait one more day for the right tools to arrive could I?
I tell you one thing, that resistor, diode, jumper whatever its called is much smaller in real life than the pics ive seen on the web. Removed the cable and ribbons, then disintegrated the part and perhaps the trace on the circuit board also, pics posted for your amusement. And no, i did not touch any pots or other items to " improve powah" lol or modulation etc.
Had a brown pants moment when my first key up shut the cb down, basically cigar plug adaptor which is soldered to and heat shrined to the power leads only had a 2A fuse installed which blew. Changed it to 7.5A and all seems to be okay thus far.
If theres anyone who can read schematics better than me perhaps be kind enough to advice on what them damaged traces on the circuit board feed / do. Its the black smudge area in pic which looks like two tracks traces are used.
Thank you.
Thank you.
