Wow!!! Galaxy LC 998v most expensive export?
undertaker
Undertaker
Apr 5, 2006
3,191
3,454
273
67
Texas
This radio claims to do 800 plus on the bird meter. 900 if you have a 100 watt power supply...
One Off radio by Lester...not mass produced.
Reactions: rabbiporkchop
I saw a video on youtube, not sure if it was lester customs or someone else, they guy was having ( not red dots ) Toshibas installed in his 2970N4, plus a few other things. Im thinking and guessing to have just the toshiba transistors put in is parts + labour = ?
Then I was looking at a Jokerman video, and he was testng some Toshiba transistors which were apparantly rated at 105 each, some were as low as 90W each, sad. He was pissed off .
A 4 pill class C comp amp with a good cooling system running at 900 watts will eventually will eventually fail if you talk on it very often. He's put those 4 transistors on a smaller heat sink without much cooling. Hopefully he didn't bias them class C for efficiency because it's a ssb rig....but if they aren't ran in class C there will be even more heat to deal with. How about those IMD levels? That is a very expensive turd.
I guess it's all about what you want. And what your willing to pay for it. That galaxy has to have some heat issues. Sure is a lot of money for a wanna be ham radio.
Reactions: LeapFrog and kc0lrp
Definetly has heat issues... Just like the ranger rci-69ffb4, at least the ranger has toshiba pills in it , but drifts like a sailboat.. That little fan inside only does so much, the galaxy dx95t with the 2 pills also runs hot.. But if you tune them the right way and not try to squeeze every last watt out of the radio , they will run a lot cooler.. If it was me though, I would rather spend the money on a radio, like a uniden grant XL, cobra 148 GTL , lots of nice radios out there to choose from, and a separate amp. You will have a better setup for the money spent. (y) But that is just my opinion, what do I know.. :)
  • @ Spanish:
    Where do i upload schematics
