Anytone 6666
vk2lyn
6
78
Hi all, Have a anytone 6666 it had one blown final which I replaced,but now tx shows low dc at 13.8 and if i increase the voltage it shows high dc which i suppose it should any thoughts would be appreciated
Mick vk2lyn
Are you checking voltage at the power supply or inside the radio? Could there be a bad connection in the power cord causing voltage drop when transmitting?
The mismatched finals are going to pose a problem. I'm surprised you didn't buy some of these.
How low does it get when you keyup
I have removed the mosfet that i replaced and no probs with the p/s and i do get some tx noise on another radio so looks like these chinnese mosfets maybe the wrong ones,i checked for any shorts on the fets but all was ok will order some better qualaty ones,thanks to all for help
mick
