erf7530 mosfets
So, if what you really mean is a "2SB817" transistor, that's an easy answer. The marking on the part usually leaves off the "2S".
But no, that one is not even close. It's a bipolar junction transistor (BJT), not a MOSFET.
Reactions: Ranch55
Try this.
ERF9530 RF Power Mosfet Transistor, 100 Watts PEP, 30 MHz, TO3PN Case
The ERF9530 feature new silicon wafer designs with greatly improved quality and durability. Palomar’s new wafer technology creates a new level of ruggedness for these RF power MOSFETs that are now able to withstand all adverse conditions - high heat, high VSWR, high voltages and current levels.
The ERF9530 is a drop-in replacement and upgrade for the ERF7530 transistor and features a new TO-3PN insulated package for the mounting screw. The ERF9530 is conservatively rated at 100 watts PEP.
FEATURES
• High Power and Economical:
Pout > 25W (100W PEP)
Gp > 10dB @ 12.5V, f=30MHz
MFR: Palomar
I guess these too have been discontinued so I have heard. Trying to find a place that still has some in stock so I can buy a couple to hang on to. I have two radio's with the RFX75 on them and I want to be able to get them fixed should I ever blow a final. Any help would be great.
ERF9530 upgrade drop in replacements .......
Normally you see that part used in audio amps when paired with a 2SD1047 you can expect about 100w out of a pair per ch. You have to match them though because the hfe is all over the place with them anywhere from 60-240. I have not see anyone use that part for RF. I have seen them used in power supplies in the past.
