Hello guys im looking to upgrade to a signal generator that doesnt take much electricty any advice on one to get?
im willing to spend a bit moreI use similar one https://www.aliexpress.com/item/KKm...al-Generator-frequency-meter/32841302045.html Good enough.
How does that work? Specs say that the minimum output is 1mV; not 1uV. How can this work for alignment? Or are you speaking of just using it for repairs?I use similar one https://www.aliexpress.com/item/KKm...al-Generator-frequency-meter/32841302045.html Good enough.
what exactly do you intend to do with?Hello guys im looking to upgrade to a signal generator that doesnt take much electricty any advice on one to get?
its a hp 8656a you think it doesnt draw alot of power?Unless it was an OLD tube type it should not use much power at all. It's only making milliwatts.Are you looking for something capable of being battery operated?
