RCI 2950DX
Delta 1
Well-Known Member
Mar 11, 2016
191
106
Lompoc Ca
I picked up a 2950dx3 a few days ago.. I was on 38L tonight, and out of the blue the frequency counter started scanning backwards on it's own, I tried to stop it with buttons on side of mic, but nothing it finally stopped at 25 MHZ .. I then had no problem at that time usesin the up and down buttons to get it back to 38L. Within 5 seconds repeated itself again.. when I disconnected the mic from radio it did stop then.. anyone experience this with this radio.. thanks Rick IMG_20180705_114540166.jpg
Two possibilities come to mind.
1) Bad tuning-knob encoder. If one of the two contacts sticks closed, it will do this.
2) Down button at the right end of the buttons is sticking closed. Worrying it for a bit might shake it loose and open the contact.
Quick check is to first pull the plug from the CPU leading to the tuning-knob encoder.
If that's not it, then unplug the front-panel buttons. Gotta remove the knobs and plastic face to do that. The whole pc board with all the pushbuttons will unplug after removing two screws.
Moving parts break first. I would suspect these before predicting the computer has gone whacko.
Which they do. Sometimes.
I put another mic I had on hand, and not doing it (yet) will see what happens.. I do appreciate your knowledge and input.. thanks Rick
