The link shows that a dropping resistor of a value of 1K is used. Might be a bit steep (too much ohmic) in value for that part. but you also have a way out - you may be able to adjust the LED brightness let alone the color by changing the LED itself - PITA of course, but possible.
Cobras' like the 19 Plus - use a "dual LED" lamp with a common cathode. - the KM 23 SOT unit uses a Common Anode. - so if you wish, you can locate SOT 23 style lamps with dual LED design - in this fashion though, the LED's will usually use up all the current available for powering it thru one LED. This means you'll have to LOWER the value of the resistor to about 680 ohms. This may help with the brightness as well as load balancing - or one LED will "suck it all in" no guarantees.
When dealing with tiny things like these LED's - it is not clear on how they do up the "Branch network" to feed power to the LED chips welded to their "cups". May be better to install an LED lamp that uses a KNOWN voltage to feed it and just remove the resistor and install a jumper - this way the LED's you replace - would have their own internal dropping resistor and power feed network so you get a true drop in versus trying to figure
You can always view the voltage drop by using the Resistors' Feed side to ground - for if the Display board is having a current draw issue, with all those LED's - that would affect brightness of all the LED's in all parts of the display - channel selector - frequency counter - so if there is a resistive "element" creeping into the harness or the display board - the LED's with the longest runs usually start showing it. So as you would have 1's in the display taking less current than )'s or 8's - these "external" or perimeter LED's start to reflect changes in brightness. Even Audio volume and TX modes of heavy modulation would also cause the LED's to fluctuate.
If you're not seeing that, just a dim LED, then more than likely it's aging - or check the DIM switch function - that too is a big indicator (SIC) of the condition of the voltage regulation in the unit.
:+> Andy <+:
