CB dedicated dipole?? Half or Full Wave?
CB590
W9WDX Member
Jun 29, 2016
1,545
1,266
173
Trenton Nj
www.590dx.com
I can mount the 1:1 center balun at 20' exactly on a pole and bring the ends down into an inverted V to the ends.. then ends would tie off just at the roof edge of my mobile home with insulators.
I can do either a half wave or fullwave..
Which should I do? Would I gain anything with a full wave?
I was going to get an A99 and the proposed Imax 2000 seems too tall for my HOA mobile home park..
Hence the 1:1 balun wouldn't stick out as much..
I am using real Times LMR-240 about 29' of it..
Reactions: AmericanEagle575
A full wave dipole would have an impedance of many hundreds if not thousands of ohms driving your SWR to near infinity with some sort or matching device and the minute gain from using one would be minuscule. Go with a half wave.
So from reading Abit.. would an inverted V with peak at 20' work about the same as an A99 at least??
The full wave has gain over the 1/2 wave. The trick to making the full wave work is feeding it with a 1/4 wavelength of ladder line. 450 ohm window line will work. Then use your balun / common mode choke to connect the coax to the ladder line.
The 1/4 wavelength of ladder line will transform the high impedance of the full wave dipole (pair of half waves in phase) to a low impedance you can work with. Hams did this kind of stuff before modern appliances and store bought dipoles so it's kind of like black magic today.
If you can stretch it out to 5/8 wave per leg you have an extended double zepp with more gain.
And back when hams did that kind of stuff transmitters had tube finals and would work into weird impedances rather well. Try that with a solid state final and see how high the SWR is and how well it works. I understand where you are coming from but with no offense to K3ACV if he has to ask these questions he is no where ready to start dealing with balanced feedlines as impedance transformers and baluns and transmatches etc. For simplicity sakes and the extreme minimal difference I suggest he get started with the simple halfwave dipole.
Reactions: 357magnum and CB590
Here's some info on the full wave dipole.
........ anyone thats ever used an 80 meter doublet on 40, a 40m on 20m, etc. knows they do actually radiate.
That's all I used for several years. An 80m doublet fed with 450 ohm ladderline to a remote auto-tuner thru a 1:1 balun. It worked quite well especially on 80,40, and 20m. Never tried it too much on the higher bands as propagation sucked on them at the time. Even earlier I used an 80m inverted V with 450 ohm ladder line straight into the shack then thru a tuner with a builtin balun. I worked a lot of DX with the little Heath DX-60B with that.
Reactions: The DB
I have tried that with modern gear and it works great. You don't even need a tuner for a single band. A simple coax choke where the ladder line meets the coax works fine. No special balun is needed.
Im not talking about working into a weird impedance. It takes some trimming of the ladder line and antenna but the point where the coax connects to the ladder line will be around 50 ohms and the vswr will be as good as your patience allows. The modern rigs never know the difference. Just because most of us don't have transmitters with link coupled finals doesn't mean we can't use this stuff.
I do agree that starting with a simple coax fed dipole is probably best. At least we can plant ideas that may be useful to him in the future instead of just telling him it won't work. Teach a man to fish.
