My shack mess.. and new bench.
Wow thanks LC. So it goes at the amp output? I run different amps off of the same antenna, could I just put it on the coax where it leaves the shack? I am going to check this out right now. Sorry for the hijack OP,I will start a different thread for this.
Chris
No, at the feedpoint of the antenna. The idea is to stop the current from flowing down the outside of the coaxial cable due to skin effect at RF. The ferrite beads on the outside of a length of cable at the feedpoint creates an RF choke. The concept is also known as feedline decoupling.
Current setup.. SWR meters up top, 1 CB and 1 for Yaesu 757GX..
Using McKinley till the Anytone AT-5555 gets here Monday night..
Don't mind the old Sharp 23 channel on right on bench.. actually works well.. that's got to get packed up..
The A99 is up and running as well. 1.1-1 or less SWR.
Reactions: Riverman
