Mobile Need Help! I am new
Roy Miller
New Member
Sep 6, 2018
3
4
3
46
I love to travel in hilly areas. In there mobile devices don’t work. I have discussed this with my many friends and most of them suggested me CB System. These all suggestion lead me to buy a CB System and mounted it in my BEAST 4*4.
The problem is my CB ANTENNA is not giving good transmit & receive. Any suggestion or could you help me out to select BEST CB ANTENNA for best transmit & receive. Well, I also don’t want that mag mount scratch my car paint.
CBs won't work either. Doesn't matter how much power you put out or what antenna you use, if there's a hill between you and the other party you're not making contact.
As for what magmount won't scratch your car paint, they all do and if it isn't the magmount that does it it is the coax which is covered in dust and metallic particles in brake dust flapping about in the wind. If you don't want to damage the paint the best thing to do is to drill a hole in the roof and install a proper fixed mount. It'll also benefit the transmit and receive as well.
I am using the SR-A10 CB antenna on a 5 week trip to alaska for 8,964 miles it stayed attached to the top of jeep cherokee through all kinds of weather and road conditions - by using this antenna depending on terrain it added 3-13 miles of reception.was easy to install and just ran the cable through the back door. there is an alan screw that attaches the antenna to the base unit make sure you take that with you we did find that came loose only once in 5 weeks but we were bounced and jarred alot on this trip so dont consider that a problem just a reminder if you do get this unit to check that every now and then - highly recommend37632225_2001924046549804_1522958380543508480_n.jpg
Iv'e mentioned it before , I have this antenna , and I have nothing but good thing's to say about it $ wise it's about the same as a Sirio and the rest . Some local Op's were so impressed with the looks and the way it performs two of them purchased them . I know it's mostly mother nature but my first contact with it was on Ch 6 , with my Antique Cobra 140 GTL , Turner + 2 , and my King Bee 250 backing it up . I heard an Op using one and just had to have it . 2 years now No problems .(jmo)
1) Does it light up when you key up?
2) I too am curious about the bug.
3) Are you telling me that if I move to the mountains, I won’t make as many contacts as I do now where I’m on “flat” land?
Seems like Shawn posted a pic of that thing on Twitter a few weeks back and it was lit up. I just can’t part with my Predator, it’s a nice looking antenna but I’m just too partial and I’m love with my Predator.
You want to talk about scratching up a roof, put a Predator on a triple mag mount on top of a dump truck. Or even worse, pop a hole in the roof and don’t use a backing plate. Can you say stress cracks? Not one of my better ideas and it’s not fun dragging a mig welder up on top of a dump truck.
For temporary uses, lay down a piece of notebook paper and drop the mag mount on it. Or clear plastic. Or felt.
Reactions: 357magnum
The Firefly...cool!
The issue is the ground wave doesn't do the best in "Hugging" the ground.
In fact with this crazy weather we've been having the air has been more stratified (layers squished together) allows for some other events like Ducting to occur, so it traps the wave in a layer of air to refract and bounce around into other regions of the that same "altitude" the layer your signal is in - but little refraction or propagation into the ground image you could use from it.
NMO mount or SO-239 "screw-on" type of mag mount? Or 3/8"-24 thread?
Reactions: sunbulls
Not mine , I have to find out , is that an add on or did I get screwed or burn it out ? Hmmm ... I need those damn lights !:LOL:
Don’t know. It’s a cool novelty ain’t it? Absolutely useless but cool as hell.
Back in the 60's there used to be an add on to the top of a mobile antenna called a "firefly" that would light up the tip of your mobile antenna when you keyed the mic. I never had one but I would guess they were just a little neon lamp. I used to see them advertised in all the CB catalogs I used to get back then.
Yeah I saw those before, they called them light toppers or something like that. Never had one either, should’ve got one, might have been real entertaining for about 2 minutes. Haha.
Reactions: Rwb
