Portable/Stealthy 20-Meter Antenna
Riverman
Nov 12, 2013
3,063
3,422
273
I am putting together a 20-Meter ground-mounted vertical using a MFJ-1620T hamstick style antenna and four 12.5' wire radials. In the next day or two, I will be posting pics and results. Stay tuned.
OK I'll ask here: Why 12.5' radials?
All the Best
Gary
Gary, I had two 25' rolls of copper wire and simply cut each in half. :whistle::D
I decided that number (4) and length (12.5') would be worth trying after studying this 2-page document from the gentlemen at Ventenna detailing how they chose the number/length of radials for their HFp 20 meter ground-mounted vertical:
http://www.ventenna.com/files/Radials.pdf
OK Jim...go for it...
However there are several statements in that article...I simply don't agree with, and my experience using ground mounted Vertical antennas, both temporary and long term installs. I do not claim to be a Engineer or know all theory(not even close), just personal experience, for my usage and working on a few commercial installs as an old wire-twister.
All the Best
Gary
All the Best
Gary
Got it, Gary. ;) Really doing it because:
Parts didn't cost much.
Have time on my hands.
Weather's getting nice after a HOT summer.
And I'm in it for the fun.
Not expecting much and will report back. (y)
Never think I am mocking or dissing anyone for experimentation...To the contrary!!!!... Just going by personal old fashion hands on stuff.
All the Best
Gary
No worries. It's all good. (y)
Maybe if I double up on the gypsum and watering and spread some BB's around, I can get my soil conductivity up to about 0.030 Siemens/meter and relative permittivity to 20. That should help performance. :D
Okay, here it is.
Parts:
MFJ 1620T - $19.95 (from HRO)
Stud Mount w/SO239 - $5.83 (from Love's)
90 degree connector - $5.99 (from Love's)
Simpson Strong Tie BC40Z - $5.78 (from Home Depot)
25’ Roll 16AWG Stranded Primary Wire (2) - $5.70 ea= $11.40 (from Home Depot)
Wire Terminals, nuts, bolts, washers – I had these on hand
Pics: (Click on each for larger image)
MFJ - 1620T
Strong Tie with stud mount and connector attached. No bending was required.
The four radials attached. (The Strong Tie came with 3 pre-drilled holes and rather than break out the drill I simply attached 2 radials to the same terminal.)
This short piece of 1X4 is used to hold the bracket on the ground. It simply lays across the bottom flange and is secured with bricks. The four bolts attach to the ends of the radials and serve to hold them in place .
All set up!
Almost invisible.
SWR readings after adjusting the length of the steel whip portion of the antenna.
These were the best I could get, so I called it good. Experimenting with different radial lengths and increasing their number would likely result in better numbers but I'm happy with these.
Impedance, Resistance, and Reactance.
Not the best numbers in the world. Nor the worst.
Patio station.
Performance:
Not much activity on 20 meters today but did make one contact to Connecticut (from Texas). Unable to do so QRP. Had to use 50 watts.
Conclusion:
It was simple to make. Didn't cost much. Not a worldbeater but it does work. And it was FUN! :D And it's not limited to 20 meters. MFJ makes their 1600T series antennas for all the bands.
Will this be my go-to base antenna? Nope. Am going to stick with my attic end fed for now. But this antenna will be used when the weather is really nice and I want to get outside to operate. And it will be fun to take camping. (If I can ever get the wife to go.) :ROFLMAO:
That's all I have for now. Thanks for reading.
After being on this thing for a while, I can tell you 40 meters is the place to be right now.
S1 noise level (compared to S3-4 on 20 meters) and operators on 40 are BOOMING in across the band like they are right next door. Too bad I can't hit the PTT! :(
Reactions: Redbeard U812
Try elevating the feed point at 6'-8' with the counterpoise as guides with short lengths of rope on ends. It should bring the swr down some
Thought about doing that with my 12' painter's pole. Ground mounting was just quicker and stealthier.
Have it put away today as the hot weather has returned.
Wish fall would hurry and get here! o_O
