Channel 13 in southwest missouri
All we need is for some terrorists to try and jam the signal with a CB and then we will be banning CBs.......
Darned CB Terrorists are coming to a theater near you!
Found out down here the RR uses that weird antenna, and the signal will mess with some of the controls in the plant. They have had control valves open and close mysteriously due to it. Not good.
Reactions: Rwb
