Mobile Another Stargun Sucker
Well, I have been working on one myself and I'm looking for investors thought you might be all in. It will cover every frequency from DC to Daylight no tuning what'ya think? This is my prototype.
It looks like you modeled it after a flu virus. LOL
Here are a couple of creations that Troy has made in the past.
The last picture was Judge Beans antenna built from two 10 k antennas and a crutch.
View attachment 27954 View attachment 27956 View attachment 27957 View attachment 27958 View attachment 27959 View attachment 27960
One big difference between Troy's antennas and that one Judge built tho...Judges crutch 10K actually worked! He won a Key-down contest with the thing...think he also had one made out of a old lawn chair too at one time.
updated version of the crutch 10K...the "flat-side" version...
images
The 10k antennas that Kale builds are decent antennas.
I have a single coil with a 22 inch shaft and a single with a 27 inch shaft.
They are both good antennas.
In fact there was some testing done on these by someone I can not remember now ( maybe Mole remembers) that had data to back up that they were very effective antennas.
I have talked to Kale many times on the phone and even though I have had my disagreements with him in the past he is light years ahead of the stuff Troy throws together even tho he is not well versed on antenna theory.
The majority of CB antenna builders claim things that need to be taken with a grain of salt.
One great example is Jo Gunn and there gain claims and the famous Multiplication factors.
Kinda like when the antron 99 first came out and they claimed it had 9db of gain.
Knowing that when you place a horizontal radiator directly on a metal roof (or too low to the ground) that it eliminates nearly all of the horizontal component, would have eliminated that design mistake too.
That horizontal radiator is more like a capacity hat. It's still primarily a shortened vertical antenna with coil loading that's no different than my screwdriver antenna I use.
That antenna doesn't need that other coil especially that close together. Placing it in the center of a metal roof is right where it should be.
My screwdriver antenna with cap hat.
The problem is that antenna is not advertised as being shorter due to the top elements. That height reduction is mostly taking place in the loading coils here. It's advertised as a "flat side". The center of a metal roof is the ideal spot to mount a vertical that is looking for a reflection of itself below. It couldn't be much worse for trying to radiate a horizontal signal. If you've ever put a dipole up way too close to the ground, you know what I'm talking about. All you have is an omni with little horizontal or directional characteristics.
