Why Do YOU Use an Amplifier?
Run the KL203 in truck, though it sitting idel till I fix the C29 limiter that was cut by prior owner and get down to 1.5w dk.. got the TS350 at home, waiting on my C148 to come back from an overhaul..
Is this an amp?:whistle:
While rolling up thru GA,TN and KY last Friday night I turned it on.
Some folks just ramble on and on and on.
Idk wtf I'm doin but it's fun
Sure seem to be a lot of clowns out there.
if i was to get a amp. it would have to be tube type.
don't like transistor amps again my opinion
I have no problem with either but on a base setup preference would definitely be
tubes, 3-500Z or large pls. Generally cleaner output, higher tolerance for unintended abuse, etc.
For mobile use I would consider selling a kidney to have a dual BLF188XR LDMOS amp though, problem is all the BS you need to get to 48-50VDC...
With 4K+vdc B+...sweet!
Though my 3-1000 or 4-1100 Glass amps do nicely, as well as my DRAKE L4Basher:whistle:
Thinking about the GS35B for 6m build...since I have a couple here with custom made sockets.
Just need to look at Xenia/Hamvention for the right "IRON" to make her "sing":LOL:
All the Best
Gary
    63Sprint has left the room.
