Base Need base antenna advice
Winds down here are antenna eaters. Had to fix mine with a HD spring and a 102" whip. works for me. Called the StarBuster looks like the old StarDuster but Texas Tough. :LOL:
Skip rolls in and it does pretty good....Chicago, Maine, NC, SC, FL, and needless to say Mex.
I have one of Jays Intercepter 10K antennas.
This is without a doubt the most robust built antenna I have ever owned and has survived many winters up here in the Sierra Nevada mountains.
It is not a cheap antenna but it is built like a brick house.
These antennas can withstand 100 MPH winds for real.
Ice and Snow no problem.
You can contact Jay here on this forum ( Jay in the Mojave) and see if he will build you one.
I don't think they are in production any more but it would not hurt to ask.
If not there are some copys of his design around but I would try him first.
Best built vertical antenna I have ever owned hands down.
Ditto..the next best omni is the Shockwave.
But if it's DX, just run a dipole is fine and fixable.
Working DX less to do with the antenna and more to do with mother nature. 14g wire at 20' would work just fine if the band is open.
I run a full wave rectangle side fed loop 42 feet to center. Easy to build, have built , moxon, jpole, dipoles, this one has been the keeper for me, has great ears and a good send. On the bucket list is the old 300 foot v beam Texas Tornado, with 10 db, maybe by fall if I can fall into a 300 meter coil of #12 wire, I have the space, and the inclination, just like this old antenna design.
