texas star dx500v or whiteline ???
jesse everett
Mar 1, 2019
33
16
18
89
I posted about finding a face plate for a ts dx500v, I forgot to mention it has whiteline on the face plate is this the same as the ts dx500v inside?.the only change I can see is there are no padding resisters,also is there a problem with removing the var.pot,i see no use for it as I will be adjusting the drive with my magnum 1 radio thanks 303
The control they use for the power knob is just too small. Won't tolerate the heat from the radio's drive power.
Unless you have an incredibly wimpy radio.
Makes defeating the control the only way to protect it from burnout. Fortunately, only two of the three terminals on the control are connected.
Some TS amplifiers wire that control so that it's zero ohms at max driver. For those, we just short those two terminals with a jumper wire.
Other models wire it so the control is turned up to full 100 ohms resistance. For those, we substitute a 100 ohm 5-Watt metal oxide resistor for the pot.
And if the radio is just too large for this amplifier, you still have three steps downward with the SSB and AM buttons.
Jesse, take a look at this site, you should be able to get quite a bit of knowledge about your TS.
http://www.cbtricks.com/Amp/txstar/index.htm
