Skipper 300
Punctuation and capitalization can change the meaning of a sentence. For example:
You can help your Uncle Jack, off of a horse.
You can help your Uncle jack off a horse.
You know I said I was sorry yesterday. If you look at today's posts I tried to use proper English. So why are you still on my ass? I said I was sorry on multiple posts,but after being accused of over posting. I stopped after a couple of I'm sorts if I offended you so deeply an apology is not enough I will gladly meet you then I anywhere you want.
Spell correct is changing words after I post I've proofread before sending. You might want to look at that
We are trying to just get you to lighten up a bit. I do not understand why you quote your own postings.
What are you saying here? Is this a challenge to a duel?
Reactions: Road Squawker
Ummmmmm.....no it's not. Spell check does not work like that and NOTHING changes AFTER you post. Never saw that happen to ANYBODY on this forum and I have been around since before the beginning. LOL
Best place I know to meet to discuss it further is off-forum.
You know I said I was sorry yesterday. If you look at today's posts I tried to use proper English. So why are you still on my ass? I said I was sorry on multiple posts,but after being accused of over posting. I stopped after a couple of I'm sorts if I offended you so deeply an apology is not enough I will gladly meet you then I anywhere you want.[/QUsorry
Reactions: Captain Kilowatt
The first thing to do! You need to get access or need to purchase a GOOD quality Tube Tester.
You can change caps/diodes, any or all the other parts in those amps, however, until you know the conditions of those tubes you know nothing.
They may light up, again that tells you squat!
One shorted or severely weak tube in a group and all the other work done previously can go BANG.
You now have 20+ tubes and know nothing about them. Inserting a tube that's like 50-70% in with a group of 85%-95% means that tube does practically zero, except make the other tubes work harder, plus overtime it will drag the other tubes down with it.
There is my first suggestion. You need a decent Sencore / BK or Hickok late version tester.
I say late version because many testers out there will not test those sweep tubes effectively.
I actually have two different testers. When I test tubes, I check them in both testers.
My 2 cents worth.
Yes, hold on to your wallet, good ones nowadays are not cheap! When you can find them in tested good working order.
http://alltubetesters.com/articles/tester_guide.htm
https://www.radiolaguy.com/Showcase/TestEquipment/Vintage Tube Tester Gallery.htm
My testers came from a Ham friends repair shop, I would never purchase one from eBay.
They need to be correctly calibrated and used frequently to be effective. IMHO
All the Best
Gary
My 2 cents worth.
All the Best
Gary
I have been looking at tube testers . but want to make sure it has a big enough transformer to check sweep tubes. I was thinking along the same lines
  • @ 357:
    holy man no activity or what?
    357 has left the room.
