Another New Texas Star DX 500V
Ranch55
Jan 18, 2016
763
972
103
Fredericksburg, Texas
I have another Texas Star DX 500V amplifier in from a friend to take a look at. He purchased it new about 2 months ago.
It is experiencing high VSWR's on any antenna, but almost flat on a dummy load. This information is according to an experienced tech who has already had it.
He asked me to take a look at it.
My initial suspicion is the DEI transistors that it came with, based on the information he provided.
I won't have an opportunity to look at it for awhile yet.
Keep you posted.
The experienced tech who initially looked at it did improve it some by working with the input tuning.
But his info to me strongly suggests issues with the DEI transistors.
An imbalance with the boards output into the combiner is heating up the combiner resistor, and one board is significantly heating up more than the other board.
When I do get to it, I'll start from the beginning and remove the boards to thoroughly inspect the bottom traces for issues and work my way up from there.
Hey Dmans, it is all interesting and enjoyable. Good talking to you on the radio.
I would start with the capacitors on the transformers to ensure that they are all within spec....cold AND hot. If they aren't, or are and drift significantly when heated, I would replace them all and try again.
If that fails, then I would dig deeper into the amp to see whats what. No need to make more work for yourself than you need to.
The previous technician has done exactly that. He is a good tech and does good work.
But, I would do that anyway, so as to be thorough.
I have seen this type of issue many times. It generally does end up being the transistors, tuning capacitors, or incorrectly wound transformers. I doubt it is the transformers, but that can cause the issue.
What is sad is that the guys down there at Galaxy uh I mean Texas Star are not getting this right when they build them.
I know that not every setup is the same but it seems that the ones built with DEI transistors are now all suspect.
Reactions: 2NC995
I bought mine a couple months back which puts it at close to the same age, and have to say I’ve been rather happy with it performance wise. Input SWR is excellent. Out of the box the preamp didn’t work (I’d be happy if it didn’t even have one) and the meter is temperamental (also would be happy if that were omitted). I fixed the preamp, and can’t see the meter where it’s mounted anyway so haven’t bothered.
Have another waiting for me in the shopping cart at Copper.
Two very easy mods that made it even better...a fan kit connected to an 1/8” jack which is controlled by the power switch, and the keying transistor removed for a direct key line from the radio so I don’t have to muck with the SSB switch or delay. Used the CW key hole for the latter mod...and love it. All “export” radios should come set up for this...IMO.
Have another waiting for me in the shopping cart at Copper./QUOTE]
Theres the problem, youre doing business with Copper, a business who has absolutely zero customer service and likes to sell inferior products.
My last copper experience ended in Paypal giving me my money back when all Sue at Copper would do is refer me to the manufacturer and hang up on me.
Id find anothet seller honestly.
I don’t have any complaints in my dealings with Copper. Not sure what you mean by the problem - “waiting in my cart” meant that I haven’t ordered it yet ;)
Reactions: Ranch55
Keep you posted.
A couple of really clear up-close images of the board in the DX500 would be very helpful as well as the values of the caps that are being used on the transformers both primary and Main transformer as well as the values of the Caps being used across the Collectors to ground. The bias resistors should be looked at carefully to make sure they are actually 10 ohm.
    63Sprint has left the room.
