Remove the cap/resistor mod, replace with a wire, restoring JP6. Repeak the radio.
Now, here is my "Swing Mod".
Remove R44.
Take a 1N4148 diode, Anode side to JP6, and Cathode side to a 10uF @ 50v Electrolytic cap (or was that a 47uF ?? 100uF ?? but still at 50v), negative side of the cap soldered to Ground on the top of the can of L14.
Run a variable resistor, 1k like the RF Gain pot, from the diode/cap you just installed, other end to where the back hole of where R44 used to be.
The bigger the cap value, the longer the circuit stays charged in between words.
The positive peaks of the audio charge the capacitor through the diode, providing voltage to the TX Buffer transistor, TR9.
With the RF Gain pot all the way up, it is like there is no modification, but when you turn the RF Gain pot all the way down, or anywhere in between, the RF Carrier "follows" the audio. The more you talk, the higher the carrier becomes, but in between words, the carrier drops to whatever setting you have it set at.
