Stryker Sr-447hpc2
A few internal pictures.
This is an irf520 version
Notice the transistors or ic's are not mounted with typical screws but instead riveted to the aluminum chassis (I'm not very fond of the rivets)
Picture tour
Reactions: snippits75
So, my new 447 HPC2 came in (after paying for peak and tune) and on my Dosy swings about 40 watts peak if RF power is turned all the way up. The problem is the dead key is at 12 watts which is not so good for my amp. How can I turn down the dead key with out loosing my top end? Thank you!!
Remove 297 and 299 worked on the one I just bought. I snipped them.
Thanks Eldorado828 for the excellent pictures!
Hey man could you send pictures of how you shipped them? I’m a bit confused on where they need to be removed. I have the tool to desolder just don’t want to remove the wrong thing. I really want to get this radio in my truck asap. Thanks! You can email me as well if you want my email
Maybe this will come in handy to other owners of this radio and future owners as well
Eldorado828, I have a question regarding the Stryker SR-447HPC@ 10 Meter Radio. After it is converted to the 11 meter band, either per your suggestion back in 2024, whether removing the capacitors, or otherwise, my question is will the radio still work on the 10 meter band and the 11 meter band with out undoing the modification? Thanks, Ernie
Ernie, once the resistors are removed the D band on the band knob becomes 11 meters. I don't recall what that band was before the conversion but it may be just band d that is lost or replaced with the cb band. The other banks are still there but I couldn't tell what they were because it was a big rig radio that stayed on 27.185.
