25,330
kopcicle
Feb 17, 2016
2,218
3,669
273
What is the resonant frequency of a series RLC circuit if R = 22 ohms, L is 50 microhenrys and C is 40 picofarads? Let's see....
There is a very useful formula for resonance: Capacitance in pF times inductance in uH equals 25,330 divided by frequency in MHz squared.
LC = 25,330/F^2
Or, rearranged:
F^2 = 25,330/LC
50 x 40 is 2000.
25,ooo divided by 2 is 12,500
330 divided by 2 is 165
So 25,330 divided by 2 is 12,665
12,665 divided by 1000 is 12.665
Square root of 9 is 3. Square root of 4 is 16. So the resonant frequency is somewhere between 3 and 4 MHz.
was just futzing around with a tank circuit and...
Reactions: WECSOG
th
This is how I learned it. The resistance doesn't matter; resonance is determined by the value of inductive reactance coupled with an equal (but with the opposite sign) value of capacitive reactance.
th
That's the way I learned it as well. You are correct in that resistance will not change the resonant frequency however it can limit the peak resonant frequency.
LC = 25,330/F^2
Or, rearranged:
F^2 = 25,330/LC
50 x 40 is 2000.
You were doing fine until I got to here...
Welcome to Core learning - it's not how you got to the answer, just that you did...
BTW = SQRT(16) = 4
Because 4^2 = 16...
SQRT(4) = 2
Because 2^2 = 4
Did you mean 2 to 3 MHz or thereabouts...?
