Do u notice any frequency drift when u first power on the MCKINLEY?
My Lincoln 2 plus starts off 100 khz high on power up and then stabilizes after about 30 mins.
Got a McKinley used...set up as base for testing. The swr check had me baffled, but after reading here, it takes it's time performing the check. The MFJ-820 works just fine.
Paired with Palomar 450 LD made contact with Auxeaucal, Mexico for a few minutes yesterday. One "radio check" on 19...."it works".....typical. Power set at 4 watt dead key, might be little high, I'll back it down some. It just seems to modulate best on SSB at 4w into the 450LD.
Find the mike small, but sound is "punchy". Just couldn't resist, had to see insides of mic. Mic is not centered, no foam, or baffle.....it's mounted offset, in a socket of the plastic cover.....looks like the open end of microphone is right up against the shell, enclosed. No holes.....hmmm? Decided to leave it alone. If it ain't broke, don't fix it....quote from my Step Daddy.
Hope to get some more contacts with the McKinley soon. So far so good......
Thanks Woody-202![]()
I have had a few good conversations with some drivers. Time of day seems key. A few locals are good. But my location is not prime. SSB is where the ops will get technical. Contact with Mex yesterday was good, in English, very clear. Detailed, location, antenna, etc.I absolutly hate the "It works" on the radio checks. Now if I do a check on lets say 146.52 on the 2 meter band people want to know what you are running. Radio, antenna, maybe even coax. They are really into what people are using to be on the air. CB just seems like a "don't bother me" zone. Sad really.
Was wondering about the RD. Have 2 sitting, need new cords. I have those and 6 pin. Need to weld them up.Add a Road Devil D104 Noise Cancelling Power microphone
Actually, it registers a little over 4w dk on AM. Backed it down some since. Prolly bout to 2 or 3w. No contacts this evening. Silence.So Redbeard are you saying you have backed your SSB output on the McKinley to 4 watts to drive your amp?
my monetary pleasure Redbeard
I was wondering what that microphone looks like inside (not I don't have to open one up). Also, the 6th pin in the middle uses a different voltage than a 980. I think the McKinley is about 2v higher and the clarifier mod is relatively easy if your hands don't shake like mine![]()
