A very LONG overdue thank you!
walterjn
Well-Known Member
Mar 15, 2019
291
408
This has taken me way to long to figure out how to do. So, without further delay (hopefully), I wish to thank LooseCannon for everything he has done to my radio!
Last year I asked who should I send my radio to to get work done. I asked about snake custom radios & was quickly told to skip that one for reasons already known. LooseCannon hit me up, told me to check out his posts & consider sending my radio to him for the work I wished to have done. I spent a bit of time checking out his posts, & found that he was a respected member of this forum, & highly knowledgeable. From what I saw, he would be one of the top guys to do the work for me.
He wanted to know what all I was wanting done. A full recap, alignment, extra channels with stock look ( no extra knobs or switches). He agreed, & suggested that I read a thread about higher modulation, for next to nothing.
Price was agreed upon, radio & payment sent off. I had a second Grant Xl that I was using at the time so I wasn't without a radio. Work was done, beautifully I might add. No hack work here! When I got the radio back, I put it in the truck checked the match, & got a buddy to give me a radio check. He wanted to wait until he made it to his base station. While he was headed to his radio shack I swapped the radios out. I wanted a true, unbiased opinion. He gave me a check on the one he had been hearing me on for a while, & said it sounded great, just like all the radios I have had in the past. I told him to give me a few so I could swap the other radio in & he could tell me how that one sounded. When I keyed up again, he told me that the second radio was MUCH louder. The signal was the same, the audio was just so much more. He said I needed to keep that radio, & send the first one back to get fixed, he still thought that the first was the one LooseCannon worked on. He called me a dog for swapping out radios on him after he learned that the second radio was the one all the work had been done to.
Since then, I have had quite a few dx contacts & almost all have told me that the audio is quite loud. I think the best one was a guy in Arizona who told me I needed to get my radio tuned. He was watching his waterfall display & kept telling me that my radio was not as clean as it should be. I finally asked him what radio he thought I was using. He said I was on some export, or an icom that needed work. He fell all over himself taking back what he said after he found out it was an old Grant Xl with a little Texas Star behind it.
So far my best contacts have been all back east, two from Windsor, Ontario, Canada, two from Florida, & so far my best one to date has been 689 in Belize!
Not too bad for an old Grant Xl with a little Texas Star behind it.
The work done was a full recap, full alignment, unlock the clarifier, & PPE (?) Mod resulting in up to 200% positive peak modulation. The hard to deal with green led was removed, & a nicely chosen white led replaced it. That white led is bright enough to see everything in the day, yet not too bright in the middle of the night. That one detail has repeatedly amazed me every long drive I make at night.
I don't have a very good watt meter, it only goes up to 100 watts, so I really can't measure more than the two lowest power levels on the TS. Those are about 50 & 75-85 watts respectively.
LooseCannon, again thank you for the amazing work! I will be sending you another Grant Xl when I have the funds & you have an empty bench.20200301_112018.jpg
200% positive peak modulation.....jesus christ. Locals must love you.
Not many locals around me. Most of the guys on cb channels are all on AM. 99% of the time I keep the Mic gain set about 3o'clock, & run barefoot. The only time I crank up the Mic gain is on AM, & I'm still barefoot. I have about a 2 watt AM dead key, just enough to consistently key the amp, nothing more. I prefer to run lower power levels, until I need more.
That's some good stuff right there. High five to Loose Cannon for getting the job done!
Most definitely!!! I never expected to get the compliments that I have on the way my radio sounds, especially from some of the guys I have chatted with on the air. I know what a few of them are running for equipment, & they sound so very, VERY clean. Almost like a radio announcer. These guys know what a good sounding radio is & have told me that I have one. I couldn't be prouder of this radio, & all I do is key up & talk on it. I really do hope that LooseCannon is proud that this radio has gotten some very good compliments.
Iv'e said this before & not sure I'm proud of it @ this point ! ( But works for me ) :whistle: I have a SRC Cobra 2k , that wasn't built for my spec's I bought it from Op that had it built . But regardless mine has preformed flawlessly ( Thankfully ) in the 10 years Iv'e owned it . I wasn't a member of WWDX then & didn't know LC . But if I have problems maybe I'll send it to him ? He can dissect Tim's work , if he hasn't already . :whistle::D
Reactions: G GOLLY WAlly
You have a cobra 2000 that has worked flawlessly for you. Nothing to be ashamed of. Especially seeing as how you didn't send it to SRC, & picked it up from the guy who did. I'm going to figure that you didn't know any better. I had second thoughts about SRC as he wasn't offering the simple channel mod I was wanting. Just the Les Comm kit, I have no desire to be able to scan every channel I have to find nobody is on. Otherwise I too probably would have a SRC radio. I am pretty sure he could undo what needs to be undone, & fix what is broken.
    boog351 has left the room.
