IF we only had the original posts, ALL of you - would see just how this played out...
@davew41 - you are not immune to that - by the deletion you removed all evidence to defend the very pricliple you are trying to knock the rest of us down by...
Where's your proof? - You DELETED you own evidence...
So for the "Sweep claim" I didn't care, you also would have seen how favorable MY review was to you - only now your proof that WE are wrong - is gone...
sure but the mod I posted shows the exact parts and exact values and the span in which changes made expand the audio
yours shows nothing except a drawing..
where are your part numbers value changes and after a sweep what is the span?
*crickets.,.
Ok you bring up a good point...
You stole someone else's work we have the proof...by that website alone...
We never faulted you originally for that...
http://www.areciboinstruments.com/Qixiang.aspx <<--- If anyone needs to review...
The picture on the left...
The U500 that's missing - that from the website...
You can find the PNG here...
http://www.areciboinstruments.com/Images/at6666.PNG
Now why is that important? How did you get the mod in the first place? Went to the site...
Then I realized the U500 in the AT-6666 and Stryker - is the same BASIC for the Lincoln - which is what I have seen and fixed - and NDA - they do apply when it comes to my job...
There, in the photo - missing U500 - well, I'll say to really broaden the audio - removing the plumbing - like Scotty would say " The more they add the more they can stop up the plumbing..."
Think about it...there's a mod here...you're just not seeing it...
U500 - missing parts, only thing that you don't see in that photo is the jumper the tech installed to cross over all that work - starts at U501 - try R515 (outside -away from U500) and jumper to C527 (outside away from U500) - then see ... I'm telling you one mod I've seen but not from an AT-6666 but a Lincoln II same platform - but Stryker? - same can be applied too...
It's why I even said anything...
You're evidence of your effort is only showing that you took a concept from another's work - and now you're claiming it as your own.
You DELETED your own defense...
You would have gotten away with it - if you were more careful with the typos...
