VFO for 148GTL...who makes(or made) this?
I remember seeing a Youtube video from some guy in Brasil who made one with an OLED display like that, and an SI5351 board to generate the frequencies. Arduino controlled.
This might be an updated single board version of it. Looks like this is on 20 Meters, too, from the display.
Here is the link that gives the whole scoop.
https://translate.googleusercontent...px-_JM&usg=ALkJrhhLPgQYqE_nxbBiezFwN1tFLKlvBA
description
DDS SOFTWARE Versão 5,14 ultima versão HARDWARE V 2.0 . DDS SOFTWARE Version 5.14 latest version HARDWARE V 2.0.
( Este DDS possui um firmware que é desenvolvido por Wander Lucio PU4WLG (This DDS has a firmware that is developed by Wander Lucio PU4WLG
e possui um grande diferencial no menu de serviço onde and has a great differential in the service menu where
voce configura este DDS para qualquer tipo de transceptor PX you configure this DDS for any type of PX transceiver
lembrando que existe alguns transceptores com o chassis frontal fora de padrão onde esta placa não possibilita o encaixe veja a lista de transceptores compatíveis com este encaixe frontal .. caso seu transceptor não esteja na lista não fique triste pois temos uma placa universal com o link no final do anuncio ) remembering that there are some transceivers with the non-standard front chassis where this board does not allow the fitting see the list of compatible transceivers with this front fitting .. if your transceiver is not on the list do not be sad because we have a universal plate with the link on end of announcement)
TRANSCEPTORES COMPATÍVEIS com esta anuncio. TRANSCEIVERS COMPATIBLE with this announcement.
COBRA 148 GTL PTT LATERAL MALASIA , COBRA 148 GTL PTT LATERAL MALASIA,
COBRA 148 GTL PTT LATERAL TAIWAN COBRA 148 GTL PTT SIDE TAIWAN
VOYAGER VR87, VR94, VR95, VR96 , VR9000, VR9090 VOYAGER VR87, VR94, VR95, VR96, VR9000, VR9090
SUPERSTAR ss3900 SUPERSTAR ss3900
MEGASTAR Mg95, Mg 97, Mg 98 , Mg 990 , Mg 990TW MEGASTAR Mg95, Mg 97, Mg 98, Mg 990, Mg 990TW
ALAN 87 ALAN 87
Modelos não listados consulte antes de efetuar a compra ou leia abaixo. Unlisted models consult before making the purchase or read below.
Transceptores NÃO compatíveis com este modelo de DDS Transceivers NOT compatible with this DDS model
Voyager VR1140 , ALAN8001 , Voyager VR148NC Voyager VR1140, ALAN8001, Voyager VR148NC
Voyager VR148 EXF , Cobra 148 INTL , Voyager 158EGTL DX e mais alguns modelos Voyager VR148 EXF, Cobra 148 INTL, Voyager 158EGTL DX and a few more models
para estes incompatíveis existe a placa universal com encoder e display remoto possibilitando inúmeras adaptações veja o link no final do anuncio for these incompatible there is the universal card with encoder and remote display allowing numerous adaptations see the link at the end of the announcement
ESTE SISTEMA GERA A FREQUÊNCIA DE IF ou FI THIS SYSTEM GENERATES IF OR FI FREQUENCY
POR ESTE MOTIVO DISPENSA FOR THIS REASON
PLL , VCO , SELETOR DE CANAIS . PLL, VCO, CHANNEL SELECTOR.
MANUAL. MANUAL.
O manual enviado em PDF basta solicitar após a compra. The manual sent in PDF simply request after purchase.
Não enviamos manual impresso. We do not send printed manual.
VANTAGENS BENEFITS
NÃO CORRE SINTONIA , ALTA ESTABILIDADE DE FREQUÊNCIA , DISPLAY COM FREQUENCIMETRO , BARGRAPH E CANAIS , DO NOT TUNE, HIGH FREQUENCY STABILITY, DISPLAY WITH FREQUENCY, BARGRAPH AND CHANNELS,
MAIOR ABRANGÊNCIA DE CANAIS ( você define a quantidade de canais) GREATER CHANNEL RANGE (you define the number of channels)
FÁCIL INSTALAÇÃO PARA TÉCNICO CAPACITADO EASY INSTALLATION FOR TRAINED TECHNICIAN
( ligar apenas os fios e fazer calibração de CARRIER ) (connect only the wires and do CARRIER calibration)
(''SE VOCÊ FOR LEIGO NÃO COMPRE ESTE PRODUTO'' ) ('' IF YOU ARE A LAYER DO NOT BUY THIS PRODUCT '')
POSSUI OPÇÃO DE CANAIS E FREQUÊNCIA , MENU DE SERVIÇO COM 18 OPÇÕES , PODE PERSONALIZAR DISPLAY COM O NOME DO USUÁRIO ATÉ 8 CARACTERES HAS CHANNEL AND FREQUENCY OPTION, SERVICE MENU WITH 18 OPTIONS, CAN CUSTOMIZE DISPLAY WITH USER NAME UP TO 8 CHARACTERS
Produtos relacionados .. Links Related products .. Links
PLACA UNIVERSAL PARA RADIOS FORA DO PADRÃO UNIVERSAL PLATE FOR RADIOS OUT OF THE STANDARD
https://produto.mercadolivre.com.br/MLB-1240515223-_JM https://produto.mercadolivre.com.br/MLB-1240515223-_JM
PLACA OPCIONAL PARA RECEPÇÃO DE HF .... OPTIONAL PLATE FOR HF RECEPTION ....
https://produto.mercadolivre.com.br/MLB-1316662659-_JM https://produto.mercadolivre.com.br/MLB-1316662659-_JM
description
ALAN 87 ALAN 87
MANUAL. MANUAL.
VANTAGENS BENEFITS
Reactions: Tokin and 2NC995
  • @ Spanish:
    Where do i upload schematics
