Identify this 667V
Hawaiian
Apr 28, 2020
5
63
I have a 667v that is only identified on the front gold strip as "Turbo mod Two thirds kilowatt 667V
No mention of Texas Star. I haven't seen one anywhere on the internet. Any help would be appreciated.
I cant figure out how to paste a photo of it on this thread. Thanks!
Photo from CB Tricks...
An “Outcom” before the texas star label, perhaps?
Reactions: groundwire
That's the exact model. Can you tell me about this unit. What's the difference if any? Thanks!!
I can’t. Cbtricks doesn’t seem to have much either...just cabinet views.
that said, I’d be surprised if it’s not much the same as the older 667, a 2290 driving 4 2879s.
You actually might be the one in the position to provide some documentation!
Reactions: Tokin
"Outcom" Is just a older Texas Star...Before they were TS...they were Outcom...So what you have is just a older Texas Star 667v....
Just like the "Killer Bee DX250" is made by Texas Star, but doesn't say TS on it...just a older version of the TS 250 2-pill...
There's also a "Skeleton" amp thats made by Texas Star, but doesn't have the TS logo anywhere on it...
Great old school amp, much better made then a new 667v in my opinion. Don't overdrive it and you might put a fan on her to keep cool. You don't want to have to replace those Toshiba finals these days, very expensive (see below).
https://www.rfparts.com/2sc2879a-mq.html
https://www.rfparts.com/2sc2290.html
Reactions: Tokin
Would pics of the internals help? I have no idea on adding pics. here. All I see is adding links.
When you reply look below the text box for an "Upload a File" button, usualy below the "Post Reply" button, click and follow prompts to add pics.
It is no different than a old school 667v
Same same same, just a different faceplate.
Just like the Killer Bee , Black Widow and others.
Keep the dead key and peak input low.
All TS amps need a fan so watch the heat, these things will consume lots of amps and make lots of heat.
Over the years I have had both the 667v, and the Turbo Mod.
I always went back to the 500 in the end.
Nothing wrong with them, just very sensitive to drive levels.
(y)(y)
Please - Heed that advice!
2290 driving 2879 - been finding out MOSFET output radios can easily "overpower" that 2290 to a point where it self-destructs from the swings the MOSFET finals can push into it.
Run the Limiter or Pad (add extra in-line resistance/Capacitance - In Series/Across) to the input drive of the amp else you will lose the "quality" of drive level that amp is known for.
