D&A raider keying tube
Staybolt
Mar 20, 2013
1,098
458
113
I have an old raider, an early one, that's missing the keying tube. It does not take a 6 or 12aq5 as the socket is bigger. I've looked all over the net but no dice.
OK. Let me clarify.
It SHOULD be a 6AQ5. It SHOULD take a 7 pin socket.
Bigger is a relative term. Does it have more than 7 pins? How many pins does it have?Does it have 5 pins like a 3-500Z with a large base socket-a 275 socket perhaps.
Can you provide a description of the tube socket? Maybe a picture?
David
OK. Let me clarify.
7 pin.
David
There were amplifiers back in the day that used a tube with a 9-pin base for keying the relay. Browning, Golden Falcon and very,very-early Varmints come to mind.
Most popular was 6BQ5.
Never have seen a D&A that used a 9-pin keying tube. And if it's old enough, it could have been built differently from what I'm used to.
Well this uses a 9 pin keying tube.
As you can see the tube dont fit
  • @ Spanish:
    Where do i upload schematics
