Texas star 350 HDV on fm
Yes, it can. As far as the amplifier is concerned, FM transmit is just a dead carrier.
Only precaution is to keep the power level below the smoke level. You should be able to turn it higher than you did for AM, but pay attention to the temperature. If it gets too hot, turn the power down.
Good deal !! Thanks Nomad. I can sleep better knowing my Toshiba's are going to make it..i did notice the box was alittle warm. I just had to make this qso.
Run it at 1/2 power it will do on SSB, keep it cool.
This is good advice considering the higher carrier on FM and the fact the amp is still running class AB with bias on FM. Lots more heat will be produced if a full power FM carrier is used. If it were mine, I might consider adding an "FM" switch, that would simply remove bias when activated for FM use.
maybe thats a good reason to keep my old class c amp then. It was most likely a one time deal, I've never talked fm on the cb before but it sure was a clean strong signal !!! Thanks for the advice.
This is one reason I have been installing a variable bias control on my new designs, so that it can be adjusted from class C for FM, to class AB for SSB. AM runs most efficient someplace in between.
